-   -   Low Hot Water Pressure (http://www.diychatroom.com/f7/low-hot-water-pressure-157847/)
tkrell21 09-24-2012 12:41 PM
Please HELP... have very little hot water pressure through out the home and my hot water heater will not drain. what do i do ??
joed 09-24-2012 12:52 PM
Sounds like the tank might be full of sludge. New tank might be needed if you can't get it to drain and clear out.
TheEplumber 09-24-2012 01:13 PM
199 Attachment(s)
The drain is plugged with sediment. Depending on the design, you might clear it with a stiff wire. Or try opening it 100% and then closing the drain valve slightly- works sometimes.
Also check to see if the hot water out nipple is plugged.
As stated, you may need a new heater.
