Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2012, 09:52 AM   #1
Low hot water pressure
Hi I recently turned on my hot water heater at our cottage (closed all winter). I have hot water, but very low pressure. What could be the problem?
Lochaber is offline   Reply With Quote
Old 06-30-2012, 10:15 AM   #2
Lightfoot's Avatar
Rewards Points: 272
The first thing i would try would be to take the aerators off the faucets and the shower heads off and flush the lines out by running the water at full blast. Probably got crud in the lines after sitting so long.
Lightfoot is offline   Reply With Quote
Old 06-30-2012, 10:43 AM   #3
Rewards Points: 13,270
Did you drain the tank for the winter? if so double check that you have the incoming water valve wide open.
If there old gate type valves it's common to have the valve fail on the inside so the gate does open up, the hande will turn but the shaft snaps off inside.
Just some ideas on things to check.
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
