Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2012, 10:57 AM   #1
I have low hot water pressure in both bathtubs, but not on sink faucets. I assume its the tub faucets. How likely is it that they've both gone out at roughly the same time? I can't be sure when one of them started with the low pressure because I don't use it. Any advice would be sincerely appreciated.
mike12 is offline   Reply With Quote
Old 02-14-2012, 11:13 AM   #2
Rewards Points: 13,300
Been doing any plumbing work on the house? If city water has there been any work being done in your area?
It's farly common to have the anti scald valves stick inside the valve bodys from some stured up trash in the lines.
Every brand is a little differant on how to fix this, so it would be best to figure out what brand it is and go on line and pull up the instrutions.
Old 02-14-2012, 12:51 PM   #3
So, I suppose the best thing to do, is replace the valve. It's fairly old, anyhow. How do I know which type to get? I think it's a Gerber single handle valve.
Old 02-14-2012, 12:56 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
hOW ABOUT A PICTURE OF THE FAUCETS?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-14-2012, 12:56 PM   #5
Any brand can be made to fit, there all just a little but differant and will need differant fittings.
Old 02-14-2012, 01:32 PM   #6
Here's a link to the faucet.
Old 02-14-2012, 01:40 PM   #7
plummen's Avatar
Ok ,can you just replace the cartridge instead of changing the whole thing?
Old 02-14-2012, 02:02 PM   #8
Well, I suppose I could. I was told by a plumber that gerber parts are hard to find, but I got the feeling the guy was embellishing a bit. I really don't know enough about this stuff, but I can't afford to pay the $500 estimate the plumber gave me to replace the entire faucet. Where might I find a cartridge for this particular model?
Old 02-14-2012, 02:14 PM   #9
plummen's Avatar
The chicago faucet shoppe,look under parts/gerber
Old 02-14-2012, 02:18 PM   #10
plummen's Avatar
There may very well be cheaper places,thats just the first one I came across and they seem to have a pretty good selection of parts
Old 02-14-2012, 02:44 PM   #11
Thanks a bunch, man. I hate to ask, but how do I know which cartridge to get? Is the only way gonna be to take the old cartridge out and match it?
Old 02-14-2012, 02:59 PM   #12
plummen's Avatar
Id give them a call and explain your situation to them,they might have you email them a picture of the faucet with the handle removed so they can tell you which one you need.
I dont remember ever seeing a single handle gerber faucet around these parts,lots of 2 handles but no singles
Old 02-14-2012, 03:06 PM   #13
Again, thanks a lot, man. I'll contact them and let you know what happens.
Old 02-14-2012, 03:14 PM   #14
plummen's Avatar
No problem
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
