Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-10-2011, 12:05 PM   #1
low hot water pressure
we replaced our hot water tank and now the hot water pressure is low everywhere. the cold water pressure is low in the shower but ok everywhere else. it was fine until the replacement. what can i do to fix it. the shower will have a little bit of water then the pipes make a weird sound and then there is just a trinkle. please help
kathytripp is offline   Reply With Quote
Old 10-10-2011, 12:11 PM   #2
Lightfoot's Avatar
Rewards Points: 272
take your shower head off and clean it. run hot water thru the pipe while the head is off to flush the crud out of the pipe.. likely when the tank was replaced it stirred up some crud and it's gett'n caught in screen on the back of the shower head. wouldn't be a bad idea to take the aerators off the faucets and clean them as well while you're at it
Lightfoot is offline   Reply With Quote
Old 10-10-2011, 05:31 PM   #3
thanks what you told me to do worked
Old 10-10-2011, 05:52 PM   #4
Lightfoot's Avatar
Rewards Points: 272
we aim to please
glad it worked!
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
