Low Hot Water Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2011, 11:24 AM   #1
Question
Low Hot Water Flow
For the past week our hot water flow has become very low in all our faucets. Our cold water is perfectly fine and in the heat we're dealing with it's not an entirely huge problem... until I go to wash dishes or cloths. To go hand in hand with the low flow, when I do try to get the hot water going it takes several minutes for any kind of temperature change to happen. We've lived in our home for three years and last year the old water heater blew so this one that is now causing trouble is only a year old. I've looked in the past forum posts similar to mine but I want to see if there are any other opinions or suggestions out there.
MRG1687 is offline   Reply With Quote
Old 07-26-2011, 02:28 PM   #2
Homerepairguy's Avatar
Rewards Points: 998
Low flow from "all" of your hot water faucets points to a problem at the water heater. Look for two heat traps at the top of the heater, one for the cold and one for the hot. Some have balls in them to prevent hot water from the heater drifting upward and losing heat. If the balls get stuck in the wrong position, they can reduce hot water flow to all faucets.
http://waterheaterreviews.com/what-is-a-heat-trap
As a test, you could connect a garden hose to the heater drain at the bottom and "carefully" open the drain faucet. If the water gushes out, then the problem points to the heat trap in the hot water outlet. If the water flows slowly, then check the heat trap on the cold water inlet. Just let enough water out to test the flow and be careful not to get burned!
HRG
Homerepairguy is offline   Reply With Quote
Removing water flow restrictors Alvis Plumbing 9 03-25-2012 10:09 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Tub hot water does not Flow at all (details enclosed) lisaz Plumbing 7 12-17-2008 08:16 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
