Low Hot Pressure To Power Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2010, 03:17 AM   #1
Low hot pressure to power shower
Hi
Last year I installed a shower cubicle. The water pressure wasn't sufficient for the new unit so I fitted a pump which has been fine for a year. Now I seem to have lost a lot of pressure on the hot feed to the shower. If I set the valve to cold i can hear the pump driving hard, however, switching the v/v to hot the pump either runs very lightly or comes to a halt.
I have a boiler supplying a hot water storage cylinder with an F&E tank above in the attic.
At first I had wondered if the particularly cold weather was affecting the supply of sufficient hot water but that can't be the case with a storage cylinder. I am also starting to think that it can't relly be asupply issue as the pump should still run on opening the valve but I would expect supply to be intermittent if the feed was not sufficient. These are my suspicions but I am a novice on plumbing.
My final thoughts were perhaps a blockage in the pump or pipes to the shower. I cant recall having filters in the fittings for the feed to the pump.
Any ideas folks?
lazthemag is offline   Reply With Quote
Old 02-21-2010, 04:52 AM   #2
I still need help if anyone can?
Old 02-21-2010, 09:35 AM   #3
Rewards Points: 1,512
The expansion tank may be saturated i.e. have lost all of its air cushion inside. An expansion tank should be somewhere between the pump and the faucets.
Although there are more precise ways of calibrating it, the tank can usually be emptied with the water turned off, the air valve closed, and the water turned back on to achieve reasonable performance. If the tank does not have a bladder or has a damaged bladder, recalibrate it every few months since the water will absorb the air little by little.
A water pump is not supposed to go on the instant you turn on the water and go off the instant you turn off the water. Should it do so regularly, your expansion tank needs calibration.
1 Week Old Shower - Water Pressure Disappeared? ClarendonCondo Plumbing 8 10-18-2009 05:41 AM
One shower lower pressure? mqcarpenter Plumbing 3 11-11-2008 10:38 PM
low hot water pressure in shower avlivewire Plumbing 2 10-18-2008 02:32 AM
Hot water pressure in the shower Randy Stuempfig Plumbing 15 01-03-2008 09:58 AM
No Hot Water Pressure In Shower Randy Stuempfig Plumbing 6 01-02-2008 07:35 PM
