Low Heel Inlet OK For Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-22-2007, 07:09 PM   #1
Low Heel Inlet OK for drain?
I am plumbing up my remodel, and I'm connecting a shower stall, lavatory sink, and toilet to one drain line. The distances between the shower and the lav and the toilet and the lav are such that I can use a wet vent from the lav for both.
As they are pretty much in line, one idea I had was to tie the 2" drain from the sink & shower into the 3" toilet drain using a 3" 1/4 bend with a low hub inlet. Is this ok? In all the books etc, I've only seen the low hub bend used to tie in a vent line.
It's easier to understand from a picture - see attached file. The line coming in from the left is from the shower (with the trap shown) and the lavatory. You can see the 3" bend with 2" low hub inlet on the far right.
Any advice would be helpful!
Thanks!!!
Simon
sjgharib is offline   Reply With Quote
Old 11-25-2007, 11:43 PM   #2
That one Guy's Avatar
Dont use the low heel 90, its not code anyways. Just put in a wye after the toilet and tie in the 2" there.
That one Guy is offline   Reply With Quote
Old 11-26-2007, 04:00 PM   #3
47_47's Avatar
Rewards Points: 44
The wye should also be tipped up 45, not flat. Do you have a vent?
47_47 is offline   Reply With Quote
4 inch 90 degree PVC elbow w/2 inch heel inlet amakarevic Plumbing 5 07-27-2007 07:59 PM
Better way to protect portable generator inlet? IvoryRing Electrical 7 05-30-2006 08:30 PM
