Old 10-09-2010, 06:35 AM   #1
GBunny
Low Flush Toilet - Water Running ?
I recently had a new low flush toilet installed. Every couple of hours it sounds like the water is running in the tank. This only happens for about 5 seconds. Any idea what is causing it?
GBunny is offline   Reply With Quote
Old 10-09-2010, 07:41 AM   #2
Most likely cause, flapper valve not seating properly. Check chain for a little slack when the valve is down. Check proper alignment, seating.
Old 10-09-2010, 08:52 AM   #3
I agree with Bill. When the tank water level reaches a certain point, the fill valve opens and adds enough water to replenish to the proper level.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Toilet won't flush hollywood60640 Plumbing 6 12-05-2009 09:33 AM
water running down waste pipe rav927 Plumbing 5 07-04-2009 10:24 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
