Low Flush Toilet - Water Running ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2010, 06:35 AM   #1
GBunny
Rewards Points: 71
I recently had a new low flush toilet installed. Every couple of hours it sounds like the water is running in the tank. This only happens for about 5 seconds. Any idea what is causing it?
GBunny is offline   Reply With Quote
Old 10-09-2010, 09:10 AM   #2
Rewards Points: 1,452
The flapper or lower tank ball is not sealing well enough and the toilet tank is slowly losing water down to the bowl. Then the float or upper ball drops enough for the tank to be refilled (topped off).
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Toilet won't flush hollywood60640 Plumbing 6 12-05-2009 09:33 AM
water running down waste pipe rav927 Plumbing 5 07-04-2009 10:24 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
