Low Flow Shower Heads - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2013, 09:01 PM   #1
Rewards Points: 422
Low flow shower heads
Can anyone recommend a good performing, low flow shower head? The cheaper the better, and can be bought at Home Depot or Menards. Thanks.
Jim McC is offline   Reply With Quote
Old 10-12-2013, 01:16 PM   #2
Rewards Points: 422
Oh well, I tried.
Old 10-12-2013, 02:42 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,570
Performing..how.
Any of the big box store brands (i.e. Delta, Moen, etc.) should serve you well.
Can't stand the low flows personally but they aren't any other options out there now to my knowledge.
Hopefully your hair does better with the newer ones than before...
Old 10-12-2013, 03:14 PM   #4
Windows: you're right, they're all now low-flow. The last two I bought worked fine once I spent 10 minutes digging out and/or modifying the flow restrictors....
....after my better half kept complaining she couldn't get the shampoo out of her hair.
Wish I had that problem....
RoyalAcresRod is offline   Reply With Quote
Old 10-12-2013, 08:13 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I always drill or punch out the restrictors in shower heads myself anyway.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 10-13-2013, 01:11 AM   #6
Rewards Points: 422
Our plumber thinks our point well may be starting to fail, because the pressure goes up and down while showering. It will be OK for a minute or 2, then it will drop for a couple seconds, then go back up. Do you think a low flow(maybe 1.25 gpm) will help when pressure drops? That's why I want to try one out.
Old 10-13-2013, 09:06 AM   #7
Rewards Points: 358
Probably not, you may get even less flow. Maybe your problem lies elsewhere in your plumbing. Water pressure going up and down could be a possible pressure regulator that may need to be cleaned, replaced, rebuilt or adjusted, if you have one. You can start by asking your plumber to investigate further if you want or you can. Check water pressures at different places, like hose bib, sinks, etc. Just a thought.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
plummen (10-13-2013)
Old 10-13-2013, 09:08 AM   #8
plummen's Avatar
Have you tried turning down the water a little bit to see if it makes any differance,does it do the same thing on any other faucets decide the shower?
Old 10-13-2013, 09:13 AM   #9
MarginallyQualified
Rewards Points: 2,464
These $5 ones are great.
You'll see them on cardboard holders clipped to the uprights.
Some will have an on/off valve built in too.
The Following User Says Thank You to TarheelTerp For This Useful Post:
jmon (10-13-2013)
Old 10-13-2013, 09:23 AM   #10
plummen's Avatar
I use those little shower heads for body sprays when I plumb low budget bathrooms/showers,they work good for that.
The Following User Says Thank You to plummen For This Useful Post:
jmon (10-13-2013)
Old 10-13-2013, 01:36 PM   #11
MarginallyQualified
Originally Posted by plummen View Post
I use those little shower heads for body sprays when I plumb low budget bathrooms/showers, they work good for that.
They work good period.
However, if you insist on spending more or your need for mark up basis on sold jobs is high... Delta sells one just like it for $50.
Your call.
Old 10-13-2013, 04:06 PM   #12
CitadelBlue's Avatar
Rewards Points: 97
Yep ..... believe they are peerless shower heads sold at Wallmart
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is offline   Reply With Quote
Old 10-13-2013, 07:16 PM   #13
Rewards Points: 422
Thanks. I will check into that.
Old 10-13-2013, 07:19 PM   #14
Rewards Points: 422
The jet pump and check valve are new, and the pressure thank was recharged when pump was installed about 1 month ago. This started after the new pump was installed. Can the pump possibly be defective? It's the "Red Lion" pump from Fleet Farm.
With the water pressure going up and down, would using a low flow head make the problem worse?
The Following User Says Thank You to Jim McC For This Useful Post:
jmon (10-13-2013)
Old 10-13-2013, 07:36 PM   #15
Rewards Points: 358
So you are on well water and started having this problem after new jet pump installation. It's possible the new jet pump could be defective, not likely though. Red lion is an excellent pump, works as expected. IMO, using a low flow shower head is not going to make your problem any worse.
However, your tank pressures may be off and need to be checked/adjusted/reset or tank may be waterlogged. Does pump cycle on/off a lot? Just a suggestion, have your plumber verify that everything is good to go with your new jet pump installation/tank/tank pressures, etc., and rule that out. Any pics of set-up?
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 02:42 PM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Multiple shower heads considerations mnicks Plumbing 2 06-29-2010 12:29 PM
multiple shower heads mbrewmeister Plumbing 1 05-29-2009 06:04 AM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 09:05 AM
