Old 10-08-2012, 05:22 PM   #1
Low flow of hot water in shower only
A while ago an expansion tank was added to our hot water tank and since then we have lost almost all water flow to just our shower. I CAN'T TAKE IT ANYMORE!!! The kitchen sink and bathroom sink are fine, its just the shower that has the problem....what can we do to fix it? I've already checked the shower head to be sure it wasn't clogged. Also the water is leaving an orange film on the shower walls, is this just mildew?
jjmunchkin is offline   Reply With Quote
Old 10-08-2012, 05:34 PM   #2
Do you have a water softner? Most often brown or orange stains are from iron in the water.
Very often when pipes get worked on trash gets knocked loose in the lines, my guess if the antiscald valve is sticking in the control valve?
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
