Low Cold Water Pressure... - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-18-2012, 05:46 PM   #1
Low cold water pressure...
Thanks in advance for the help. I live in a mobile home. I drained my water heater and didn't think to flush it out. Now I'm pretty sure there is sediment in my cold water lines. Very low pressure in only parts of the house. Hot pressure is fine. Is there a way to flush this sediment out?
jumperj is offline   Reply With Quote
Old 05-18-2012, 06:44 PM   #2
Rewards Points: 1,294
How did you drain the water heater? Did you use the drain valve at the bottom of the tank? Not sure how the cold water lines could be affected by emptying the tank. Are you sure you have all valves turned on?
danpik is offline   Reply With Quote
Old 05-19-2012, 06:47 AM   #3
biggles's Avatar
the cold water line feeds the HWH but continues onto the fixtures as cold water...remove the screens off the faucets effected...stuff in the HWH can't go into the cold water only the hot water feed out does if crap trips out into the pipes
Old 05-19-2012, 06:52 AM   #4
I hooked up a water hose to the water heater drain valve at the bottom. Not sure why cold line would be affected. I just know I had good pressure before I drained it. And now...not so good.
Old 05-19-2012, 08:29 AM   #5
Rewards Points: 12,790
When you drain a tank like that the in rush of cold water to fill it can stur up any trash in the bottom of the tank. Just do as suggest and remove the aerators and clean them out.
http://images.search.yahoo.com/image...mb=Xwi4JCiNfjZ
Those fine screens tend to plug up over time anyway.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Low cold water pressure in shower peezee Plumbing 2 05-07-2011 05:30 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
