Low Cold Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2012, 06:37 PM   #1
low cold water pressure
what can I do I have change fracets and can get pressure for a day at most mostly only a few minutes and the longer the water is on the lower the pressure HELP?
marylou53 is offline   Reply With Quote
Old 05-03-2012, 07:13 PM   #2
Rewards Points: 582
may have a bad pressure regulator...need to see meter area to tell if you even have regulator...
Old 05-04-2012, 08:57 AM   #3
I=E/R
a7ecorsair's Avatar
Are you on city water or do you have your own well, pump, and pressure tank?
a7ecorsair is offline   Reply With Quote
Old 05-04-2012, 07:50 PM   #4
I share water meter with a community and no one else has complain of low water pressure and it is city water
Old 05-04-2012, 08:09 PM   #5
I=E/R
a7ecorsair's Avatar
What makes you think you have low pressure? Can you post an example?
Old 05-04-2012, 08:10 PM   #6
Rewards Points: 582
my guess you have a pressure regulator that is bad.....do you have a shut off valve for the whole house...
Old 05-04-2012, 11:43 PM   #7
Homerepairguy's Avatar
Rewards Points: 998
what can I do I have change fracets ...snip
Is your problem only on one particular faucet or on all cold water faucets including the hose bibs outside?
HRG
Homerepairguy is offline   Reply With Quote
Old 05-06-2012, 09:06 AM   #8
I believe the only regulator is at the meter and it is shared by all in the mobile home park and only I have the problem no one else has complained and yes it is all the cold water outlets
Old 05-06-2012, 12:57 PM   #9
Rewards Points: 998
... and yes it is all the cold water outlets
The "low cold water pressure" subject is probably misleading. If all cold water faucets are affected, then all hot water faucets are probably affected also.
1. It could be a bad pressure reducing valve (aka pressure regulator) as others have suggested.
2. It could be a bad backflow preventer check valve if the city installed one. Call the city and ask them if they installed one.
Both items above would be unique to your home only.
3. Also verify that the shutoff valve on the main water line coming into your home is fully open. You could have two shutoff valves. One right at the city's water meter and one where the water enters your home. Open a couple of faucets in your home and then close and open the valve(s) on the main water line to try to clear them of any debris just in case.
HRG
The Following User Says Thank You to Homerepairguy For This Useful Post:
marylou53 (05-06-2012)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low cold water pressure in shower peezee Plumbing 2 05-07-2011 04:30 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
