Louvered Door For Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2010, 08:23 AM   #1
grapesoda's Avatar
Louvered door for water heater
My electric water heater, softner and expansion tank are in a small room the size of a closet w/ a louvered door. Can I replace the door w/ a solid one?
grapesoda is offline   Reply With Quote
Old 01-31-2010, 08:32 AM   #2
DIY staff
Rewards Points: 7,174
You can --If you can add ventilation somewhere else.
Can you cut in a return air grill into the wall?
Old 01-31-2010, 09:42 AM   #3
Licensed Master Plumber
Since there are no appliances in there that burn fuel of any type, you can put a solid door on if you want. The only consideration I would have is for moisture, but if you cut a couple inches off the bottom of the door it shoud be fine.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 01-31-2010, 09:59 AM   #4
grapesoda's Avatar
Thanks, that's the answer I was hoping for. I hate the look of those doors, and that's the first thing you see when you come in the front door. I may pass for now on a wall vent, since it would have to be in the foyer. I'll watch closely for moisture. The closet is at the far end of the kitchen away from all the appliances. Thanks again!
Old 08-09-2010, 10:38 AM   #5
I am having a new high efficiency gas furnace/ac unit installed. The A/c unit is outside and the furnace is in the basement. There are louvered doors in the basement for the furnace. The company installing the new furnace told us we need to have a louvered door at the top of the basement steps or no door at all /(currently a solid door). Are there any other options? He says this is due to the efficiency air flow necessary/carbon monoxide...please advise.
chasnr is offline   Reply With Quote
Old 08-09-2010, 10:44 PM   #6
Rewards Points: 1,512
Current codes require more ventilation for gas furnaces and gas water heaters. This may require that the door from the main house to the basement have a louver, and/or holes for vent ducts be cut in the house foundation.
A closet with just an electric water heater may be fully closed off with a solid door. Except if it is in the corner (of exterior walls) where closing off the louvers to the basement interior could result in freezing in winter. (Such a closet should not have the walls between it and the interior insulated.)
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
