Old 09-28-2010, 10:49 PM   #1
Loud well pump
Newbie plumbing question... I moved into my 15 year old house 3 years ago. My well pump has been VERY loud since the day I moved in. I mean LOUD --- the floor above the pressure tank even vibrates a little. I've had a plumber check it out and he said that everything looks fine. The only thing I can think of that causes the noise is that the inlet into the house (from the well) is across the room (~18ft) from the pressure tank. I'm thinking the length of copper pipe causes some cavitation...? We have no problems at all with water flow or pressure. I've looked and can't find the make/model of the pump. The noise is just dang annoying! Is this anything that I can fix somehow or is it something that I just shouldn't worry about? Thanks for any help you can offer!
bflossn is offline   Reply With Quote
Old 09-29-2010, 11:44 AM   #2
Loud well pump
Sometimes they get loud when they are old.
The bearings get worn.
Try a new pump or, live with it until it dies.
Mr. Green is offline   Reply With Quote
Tags
noise, pressure tank, well pump
neighbor's loud pond pump meanmom47 Landscaping & Lawn Care 7 11-08-2009 05:45 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
LOUD sump pump SusanGG Plumbing 4 09-30-2008 07:29 AM
