Old 04-13-2008, 03:17 PM   #1
loud surround tub
Hi everyone. I am not at all knowledgeable when it comes to anything that requires fixing up so forgive me if I'm unable to explain things well.
There seems to be a lot of noise when entering and exiting our surround tub. Is this normal? I've been in this house for about 4 years and I didn't notice this at first but it may be that I am just noticing this now. Is there a problem here? I have also noticed that the drain isn't flush with the bottom of the tub but there are no watermarks on the ceiling underneath so I am assuming that it isn't leaking. What do you think?
Thanks!
Non-handyman forever is offline   Reply With Quote
Old 04-13-2008, 11:06 PM   #2
Moderator
Termite's Avatar
loud surround tub
Be more specific about what you're hearing.
Are the noises happening when you step into the tub, and do they originate from your weight in the tub? Or are the noises from the pump motor?
As for the drain, post a picture.
Tub Surround, Painting, Durock or Greenboard, and Spacking Questions? golfer2b Plumbing 7 04-17-2008 09:59 PM
Tub surround removal CowboyAndy Plumbing 3 03-13-2008 01:13 PM
New house, freezing temps, loud popping noises lp61006 Building & Construction 11 02-22-2008 06:36 PM
Air bubbles forming in new tub surround LBreaux General Discussion 6 02-12-2008 10:59 AM
What to do with area about tub surround? geowoman Remodeling 7 05-05-2007 02:56 PM
