Old 01-18-2009, 05:07 PM   #1
sadly not handy ;)
Default loud jackhammer-like noise from hot water pipe
Hello,
I'm afraid I'm not really handy and am going to be calling a plumber to have a look at this, but I wanted to see if anyone here has experienced something similar or knows what's going on.
This is the situation in a house in Toronto (Canada), so it's fairly cold, about -8 degrees Celsius today. Not sure how old the house is, about 25 to 30 years I guess? The basement kitchen sink has a simple Moen faucet. This faucet has only one lever, turn to the right for cold, turn to the left for hot, and pull the lever up to turn the water on.
Anytime the lever is set for fairly hot water, AND the lever is pulled up all the way so that the water's running as fast as it can, an unbelievably loud vibrating noise is heard from the pipe connected to this faucet.
The sound is extremely loud, it sounds like a jackhammer is being operated inside the wall.
As soon as the tap is shut (or either the water-flow or the water-temp. is reduced) the noise ceases.
As stated the problem only occurs when the water is anywhere past fairly warm AND the water is running full blast.
There's also a laundry sink in the basement. We've noticed that if the hot water tap in the laundry sink is running, then the kitchen sink's tap never makes any noise, the water can be run as hot as one likes at full blast without incident.
The laundry sink and kitchen sink are on opposite sides of the same wall (i.e. the rears of the sinks are attached to the same wall, one sink is on one side of the wall and one on the other).
So anyone have any idea what going on? I found some descriptions of a phenomenon called 'water hammer' but I'm not sure if this is it. (Water hammer seems to be a hammering sound that occurs when a tap is shut off.)
I think there may be air in the pipes. One time the City was doing some work in the neighbourhood and turned off the water supply. When the water was turned back on, we were told to run our taps for a bit to get the air out of the pipes and the same kind of jackhammering sound we now have was heard, but it stopped after the water ran for a bit.
I'd greatly appreciate your comments or suggestions.
omar is offline   Reply With Quote
Old 01-18-2009, 11:34 PM   #2
In my experience that problem can be caused by a bad cartridge in the back of the faucet. In moen faucets the back of it where the water runs through are full of o-rings and if one of them are woren out or something else is getting worn or loose it can cause a fluttering motion that will sound just like water hammer. Try to replace that. Hopfully this helps....
lilh2o3 is offline   Reply With Quote
Old 01-19-2009, 11:34 AM   #3
sadly not handy ;)
Thank you for the advice, I appreciate it.
I don't think I'll be opening the faucet myself so I've called someone to have a look at it.
Old 01-19-2009, 03:22 PM   #4
Make sure your supply valves under the sink are fully open. If you have one partially closed it can cause that.
Old 01-21-2009, 12:29 PM   #5
sadly not handy ;)
Jorg, you hit the nail on the head!
For some reason the hot water supply for this faucet was just barely on. Once I turned the hot water supply on properly, the problem vanished.
Hopefully this thread will be useful for others who encounter this issue.
Thanks again for all your help!
(And my thanks to everyone on the forum here, it's a great resource.)
Old 01-22-2009, 11:37 PM   #6
cartride has NOTHING 2 do with it......angle stop not open all the way can cause it,,,,,,some times
drunknmaster is offline   Reply With Quote
Old 07-18-2009, 05:28 PM   #7
Default Had the same problem, fixed!
Had this problem in two pipes, one of them for YEARS. Fixed them both, thanks jogr!
Rhyyke is offline   Reply With Quote
Old 10-11-2009, 12:32 AM   #8
Thumbs up Thanks, Jogr!
I'd been dealing with hot water faucet fluttering noise for weeks. I'd read several suggestions online, but your suggestion to make sure the hot water inlet valve was open all the way got me back under the sink. I discovered there were two valves in series...one was fully open and the other, half-open. A few turns of the valve, and, problem solved! Thanks for the simple and effective advice!
fwilliam is offline   Reply With Quote
Old 10-11-2009, 06:31 PM   #9
I love Holms on homes... just so happens he had a show recently(repeat) that dealt with this exact problem. its usually(but not always) caused by pressure buildup in the pipes and poor anchoring of the pipes, like how a garden hose stiffens when closed(happens over time in older houses)
his solution was installing what he had called a "hammer stop" its just a copper tube sealed at the top 4-6 inches in length that installs in an upright vertical position to the output line(must be void of water), air is easy to compress and acts like a shock absorber, thus preventing the pipes from rattling from pressure buildup.
P Marage is offline   Reply With Quote
More On This Topic
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
We're hooking up the angle stops for the water supply to the sink right now. I've got the cold water side done and now I'm going to do the hot water side. I've got to cut this cap off the copper pipe and then fit the valve onto the pipe, so, let's go... Read More »
I’m Lee. I have a degree in architecture and about ten years construction experience, and today we are replacing the hot water pipe and valve. Now we’ve already installed the valve, which is a two outlet valve- one for the sink and one for... Read More »
We did here in our houses. We have the good insulation but it was not good enough for me. So when we got all these packages from the company's with all these Styrofoam chips in there, we used these chips and put them on top of the ceiling and add to the... Read More »
Hi! I'm Arnesia Frances from Bell Nursery in Burtonville, MD for Expert Village. We are going to help you get your garden ready for the Winter. This is probably going to be the last time that I water out here because it is really starting to get cold and... Read More »
Popping noise where PVC pipe leaves house sb5115 HVAC 7 01-30-2008 05:18 PM
pipe layout and water flow moneymgmt Plumbing 4 01-25-2008 07:07 PM
Popping noise where PVC pipe leaves house sb5115 HVAC 0 01-22-2008 07:01 AM
Strange noise associated with hot water - New Question johnny Plumbing 2 08-26-2007 10:40 AM
Loud pssst noise when flushing mcvane Plumbing 3 08-22-2007 10:11 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
