Loud Dripping Sound Heard While Draining The Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2014, 01:01 PM   #1
Rewards Points: 58
Loud dripping sound heard while draining the sink
I noticed recently sometimes if someone is draining water from second floor bathroom sink, I can hear loud dripping (or knocking) sound downstairs. The sound went away in 30 sec. I first thought something is vibrating downstairs, but later on I confirm the sound is from above the ceiling. I monitored the ceiling for a couple of weeks, and haven't noticed any water leak. Has anyone experienced this before? Thanks.
shiyang100 is offline   Reply With Quote
Old 01-15-2014, 01:36 PM   #2
DIY staff
Rewards Points: 7,174
PVC drains can be noisy----so unless you see a leak--it's likely just water in the drains.
Some really high end homes still use cast iron drains because they are quieter.
Old 01-15-2014, 02:22 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 834
May also be pipe rubbing on wood due to hot water expanding the pipe. Hard to locate sometimes
Old 01-15-2014, 02:29 PM   #4
Rewards Points: 58
It is like something is vibrating vigorously. The first time, I thought about the cups in the cabinet were shaken by the earthquake. But I am in new england, supposely no big earthquake.
Old 01-15-2014, 02:38 PM   #5
Plumber
Rewards Points: 834
Could be the water lines vibrating. More commonly referred to as water hammer. It's not uncommon for water pipes to next to a drain line. Is it noticeable when the faucet is on or slightly open?
Old 01-15-2014, 02:39 PM   #6
Rewards Points: 58
The faucet is off. It only happens when draining the water.
Old 01-15-2014, 05:41 PM   #7
Mad Scientist
I've got this too, in my bathroom sink drain. I've learned to ignore it. Running hot water down the drain results in a pretty distinct knocking/tapping sound coming from the wall. It's just the PVC pipes expanding and rubbing as they heat up.
If you get different results testing with different water temperatures, then I'd say you've got the same issue going on.
McSteve is offline   Reply With Quote
Old 01-17-2014, 07:56 AM   #8
Rewards Points: 58
I did some tests at home last night. With the same sink, I was upstairs, and my wife was downstairs. I first started with running cold water. No noise. Collected enough cold water and drained it, no noise. Running hot water, the noise appeared in about 15 sec. I can hear it hehind the wall on the second floor, and my wife heard it above the ceiling. It is loud, fast, high frequent knocking/tapping sound. Turned off faucet, the frequent noise stopped immediately. But in the next 5 min, you still can hear knocking sound every 15 sec or so until it completely went away.
So it might be air in the pipe or thermal expansion. What can I do?
Old 01-17-2014, 12:20 PM   #9
Rewards Points: 320
IMO, what your hearing, as others have mentioned, is the normal thermal expansion of the pipe warming up and cooling down. You also have the wood the pipe is traveling through and the brackets securing the pipe expanding and contracting, which is contributing to the noise as well.
I'm not sure how to fix it, I would suggest pipe hangers, supports that have rubber cushions and drilling a bigger hole for the pipe that's traveling through the floor/ceiling. The pipe that's running through the floor and ceiling may be too tight with not enough room for expansion. Not sure how this could be accomplished or if it's even practical without removing drywall, etc. Sorry I couldn't be of more help to you. Stay tuned, let's see what others reccommend. Thanks.
jmon is offline   Reply With Quote
Old 01-17-2014, 12:42 PM   #10
Rewards Points: 58
Thanks JMon. We moved into this new house six years ago, and haven't had this problem until a couple months ago. That's why I hesitate to believe it is pipe expansion. Otherwise, it should be there since the beginning.
Old 01-17-2014, 01:03 PM   #11
Rewards Points: 320
I agree. After you have investigated it a little further now, you appear to have some other issue going on affecting just your hot water line.
Just curious, probably has nothing to do with it, but whats your incoming water pressure set at? Can be checked at a hose bib or sink.
Old 01-17-2014, 01:10 PM   #12
Rewards Points: 58
But I just couldn't figure out what other possibilities are. Are there any other tests I should do?
Old 01-17-2014, 01:20 PM   #13
Rewards Points: 320
Whats your incoming water pressue set at? Can be checked at a hose bib or sink.
Old 01-17-2014, 01:31 PM   #14
Rewards Points: 58
I will check it out this weekend. But I only have the problem with one upstairs bathroom sink. Do you think water pressure still might be the cause?
Old 01-17-2014, 01:49 PM   #15
Rewards Points: 320
Probably not. But then we can rule it out for sure. Thanks.
slow draining bathroom sink jbkenn331 Plumbing 11 12-07-2012 01:13 PM
Draining wshing machine/ sink to sump. tedennis Plumbing 5 11-19-2012 08:31 PM
Toilet slowly draining, sink causes level to rise emeryj23 Plumbing 4 09-04-2012 10:28 AM
loud boom sound somewhere in house, every few days Patti L HVAC 3 03-04-2012 02:52 PM
Popping sound (loud) in hot water tank andrewd80 Plumbing 2 12-25-2009 05:38 PM
