#1 |
Loud banging from water pipes when hot water is on
My home is 12 years old and I've been there 10 years. This just started. In the bathroom when I turn on the faucet in the bathtub I'm hearing an EXTREMELY load banging noise. It often stops when I turn the faucet to a colder temp or if I turn it off. So I'm assuming it has to do with the hot water pipes. It doesn't do this when the bathroom sink is turned on...just the tub. I'm on a concrete slab so there is no crawlspace or basement underneath. It sounds like it's in the wall behind the shower. I would think that if the builders hadn't secured the pipes properly I would have experienced this before 12 years. What can I do about this? Please tell me there is a way to fix it without tearing open the wall. That is beyond my expertise and with this economy there is no money in the budget to hire someone. Help.
#2 |
Wire Chewer
If you have access to the pipes try to secure them further.
Also look at the hardware store for something called a water hammer arrestor. They will reduce this racket which is due to the water suddenly stopping to flow.
#3 |
As I stated in my post I don't have access to the pipes and it occurs when the water is turned on...not turned off. So, the water hammer arrestor will do no good.
Any other suggestions? |
#4 |
Experienced
Hello and welcome mhintn, to the best darn DIY'r site on the web.
How is the flow when the valve is turned on, is it constant? It sounds to me like you have a seal in your fixture that is interupting flow (flopping around in the valve) causing the water hammer you are hearing. Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Hi and thanks for the welcome. I'm glad I found this site.
The water flow is good: constant, strong and no recent change in the flow. |
#6 |
Experienced
Still sounds to me like you have a faulty shower mixing valve.
I would pull the valve apart and investigate possible causes. Mark
| Display Modes | |
| loud jackhammer-like noise from hot water pipe | omar | Plumbing | 15 | 01-08-2012 02:53 PM |
| water heater drip | kdange1 | Plumbing | 5 | 05-04-2010 04:24 PM |
| Banging Pipes - How to Locate Them - Issue Is Not Water Hammer - Please help! | mikey33442 | Plumbing | 1 | 11-19-2009 05:44 PM |
| How to (retrofit) insulate/air seal cantilever with hot water pipes in it? | KatieAK | Remodeling | 7 | 11-04-2009 09:10 AM |
| Installation of new pipes on Water main... | NJE | Plumbing | 3 | 02-05-2007 01:06 PM |
