-   -   Lost Hot water pressure (http://www.diychatroom.com/f7/lost-hot-water-pressure-87911/)
brile 11-27-2010 10:11 PM
Hi. Earlier today, I needed to shut off the cold and hot water in my home. I shut off the water in my basement near my water meter, and because I was told it would be a good idea, I also shut off the hot water coming out of my electric hot water tank. (I'm thinking this was my mistake).
I had the water shut off for approximately 3.5 hours. I turned the main water supply to the house back on, and the hot water coming from my hot water tank. Ever since I turned the water back on, I am hardly getting any hot water out of any of my taps. I may get a burst for a few seconds, then nothing. The tap in my laundry tub does dribble hot water continually, but no pressure at all upstairs, after a few seconds. No, I did not shut the power off to the hot water tank. No, I haven't drained the hot water tank.
When I leave the hot water running in my laundry sink, which is across from my hot water heater, I can hear the hot water heater "doing it's thing" but as soon as I shut the tap off, the hot water tank gets quiet after about a minute or so.
Am I forgetting to do something? Is this dangerous in any way? Help? I'm a little nervous about leaving it as it is overnight so any help would be greatly appreciated.
Work4living 11-28-2010 04:54 AM
Brile,
I see possibly 2 scenarios....
1) The valve you shutoff at the water heater may be failling to fully open or is obstructed with debris. This is not a safety problem as much as a pain in the neck. Is this valve on the Hot line of the water heater or the cold supply to the water heater? Look on the top of the heater, the outlets usually are marked with either an H, C, Hot, Cold Or even a blue and red plastic ring on the housing of the heater by the water inlets of the tank.
2) The other scenario is the easier, "however I am doubtful this is the case since you say the loss in pressure/volume is on the hot side only". But check your aerators on the ends of your faucets. They unthread from the faucet, righty-tighty lefty-loosey. There is a screen and a flow reducing disc in there look for debris that is blocking flow of water. Clear the debris and reattach the aerator to the faucet and see if there is flow to it.
However, if it is the first scenario, there are other choices, Trying this repair yourself, or calling in a professional.
Since you already know how to shut off your cold water by the meter. This makes checking things out easier.
It is possible that the valve which I think is the problem is either not openning or is obstructed by debris from the heater.
To test this I would suggest connecting a garden hose to the drain valve at the bottom of your heater. Bend the end of the hose over to stop the flow of water. Open the drain valve on the heater while holding the end of the hose kinked over to block flow. Take the hose to the laundry tub and unkink the end to allow the water to flow in the laundry tub. Is there volume and pressure? If so, kink the hose, shut off the drain valve and detach the hose.
Now is where you have to decide if Dismantling or replacing the valve is something you can handle or if you need to hire a professional.
What type of water lines do you have, Copper, Galvanized, or Plastic?
oh'mike 11-28-2010 06:29 AM
Hi,work4aliving---I think you nailed it---broken gate valve---those are the ones with the round handle--
Famous for breaking in the closed position---you will want to replace that with a full port ball valve--
What kind of pipe do you have?
secutanudu 11-28-2010 07:46 AM
Does the valve you shut off at the water heater look like this?
http://t0.gstatic.com/images?q=tbn:A...BYhEhxTx5pjDc6
Or does it look like this?
http://t0.gstatic.com/images?q=tbn:A...4lavXB6zSvQ6bZ
brile 11-28-2010 08:31 AM
1 Attachment(s)
Reading your replies I am thinking it's quite significant that from the second I shut the handle off, it started leaking, and continued to leak even when I opened it back up. I have copper piping coming out of the hot water tank and a gate valve with a round handle, just like the red one shown at the top of Secutanadu's reply to my post. Just to clarify, the now suspected broken gate valve shuts off the hot water coming from the tanks to the pipes going out into the house.
I'm not jumping at the opportunity to fix this myself, but was wondering what would be involved?
I can guess, shutting off the water supply to the tank, cutting the pipe just above and below the gate valve, and installing a full port ball valve. Would I need a hack saw, sauder gun?
I've included a photo.
Thanks for taking the time to reply.
Cheers
Work4living 11-28-2010 08:43 AM
Brile,
Things are looking up for you!!!!! Of course before you start remember to shut off the water at the meter.
This is totally doable for you!! I am unsure of your Hardware store but if there is Lowes or Home Depot close by. Look for a 1/2" Sharkbite Ballvalve.
http://www.cashacme.com/prod_sharkbite_ball_valve.php
All you need is to cut the copper above and below, debur the outside edge of the copper tube and push the pipe into the ends of the valve and your done. No soldering!!
However if you would like to try your hand at soldering. You will need a propane torch, solder, flux and a quick tutorial in soldering. I would reccomend one of the above stores again. they will have it and can help show you how to use it.
brile 11-28-2010 08:51 AM
Thank you Work4living, that's the best news I've had in a few days! I've never handled a torch or soldered anything so the shark bite sounds like a plan. Questions, question, questions though. First, do I need to drain the tank before I start? I already shut the power off to the tank before going to bed last night because I was worried about what was going on with it. Can I use a plain old hack saw to cut the pipe? How do I de-fur the edges? There is a home depot close by so they should have everything I need. Thanks again for your help:))
Work4living 11-28-2010 09:29 AM
Brile,
Your water lines exit the top of the heater, so no you dont have to drain the tank. Buy a pair of copper cutters they have inexpensive models around 5-10 bucks. I reccomend opening the hot and cold side of a faucet in the upper floor and basement as this will drain off any pressure and residual water from the lines. You can use a hacksaw but if you do not cut squarely then you may have a hard time using the sharkbite. A file can be used to debur the outside of the copper. basically you want to smooth the edge, give it a bullet nose look... This helps so that the sharp edge of the copper cut does not cut the o-ring seal in the sharkbite.
Take note that when pushing the copper into the sharkbite fitting sometimes it is easier to twist the fitting a little while pushing the copper in. The tube should push in about 1" into the fitting. The Home Depot can demonstrate using the fitting/valve.... It is truly simple!!!
The tank is not a problem either, they all make pops and noises when heating. It is actually the scale and mineral deposits moving in the convection current of the water and then hitting the sides of the tank......Normal nothing to worry about!!!!
GOOD LUCK! YOU CAN DO THIS! I HAVE FAITH IN YOU!
rjniles 11-28-2010 09:33 AM
You may have a problem trying to get the new valve in place. You have to get enough vertical movement in the pipe to get the new valve into place. Even if you do not want to solder, you will need a torch to clean all that solder splash off the pipe. If you cut enough pipe out to remove the solder splash you will probably not have enough left to reach the valve.
Get a cheap copper tubing cutter to cut the old pipe, not a hacksaw. The tubing cutter will have a de-burring tool on it.
You also might want to consider a compression valve instead of a Sharkbite valve. It will be easier to get into place than the Sharkbite.
brile 11-28-2010 02:17 PM
I did it!!!!
1 Attachment(s)
I would have posted sooner, but I've spent the last 20 minutes dancing with joy around my house:)
Turns out, I had a pipe cutter, and even a 5' length of spare new, half inch copper pipe sitting around. I went to Home Depot and picked up a new shark bite ball valve, and just incase I ran out of pipe, I bought a spare little shark coupler, which in the end, came in handy. I practiced cutting on the spare pipe, then went after the real thing. No soldering, no fuss, no muss. I just rammed the cut and cleaned (with a file) ends of the copper pipe into the new valve and rammed them in. The water is turned back on, no leaks in the new connections, and best thing, hot water coming out of every faucet! Now, I have 2 days of dirty dishes to catch up on (no dishwasher) then I attack that stuck hot water faucet in the tub with the handle and sleeve puller kit. Thanks for all your support, advice and encouragement, especially Work4living!
Work4living 11-28-2010 02:26 PM
Brile,
I am glad all worked out. Always Happy to help!! Looks like a terrific install. Sorry about the dishes. I am also glad you got the coupling. Now all we have to do is teach you how to solder and you have a new profession!!!!!!!:thumbup:
brile 11-28-2010 02:59 PM
Thanks Work4living. I have a really disgusting bathroom in the basement that we don't dare use which is on the radar for a complete gut and rebuild next year. Perhaps I'll get into some soldering then....
Cheers
