Old 08-01-2012, 09:57 PM   #1
jburd964's Avatar
The Lost Art of Running Screw Pipe
Could so one help me out with measurments for running screw pipe? I can make it work if there's enough pipe on hand, but I would like to be better. Is there a formula to allow for measurements that account for the pieces once there screwed together? Say I want a overall 1/2" x 10" finished length nipple screwed into a 90. How much should I thread nipple so when it's put together it makes a completed piece 10". Wording this isn't as easy as the question. Is the a table for different common household pipe sizes, maybe even one including allowances for different fittings overall lengths ? Question is also for other pipe sizes as well 3/4", 1"..
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 08-01-2012, 10:12 PM   #2
Super Moderator
One of the old timers might have a chart somewhere---I used to know the approximate take up for 1/2" and 4" --But those numbers haven't been needed for years in my word---
Old 08-01-2012, 11:18 PM   #3
Doing it myself
Alan's Avatar
Typically (given good thread pattern and cut) threads on a pipe will disappear approximately 3/8" into the fitting. Give or take just a little depending on what position said fitting needs to be in when you're done.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (08-02-2012)
Old 08-01-2012, 11:21 PM   #4
Doing it myself
Alan's Avatar
I'd like to also add, that the example in your question is slightly vauge, given that you haven't mentioned where you want your 10" measurement to end up in reference to the 90. End of 90 to end of pipe? In that instance, i'd measure the 90 at the 10" mark on my tape where I want it to end up, whether it be end of pipe, center of fitting, end of fitting... etc etc...
Then i would note the measurement on the end of the fitting where i want my pipe to screw into, and add 3/8" to it. That should be the length of nipple you need to make up your overall dimension, wherever you're hoping it ends up at.
Journeyman Plumber
Old 08-01-2012, 11:42 PM   #5
jburd964's Avatar
Is the 3/8" standard for all household pipe sizes? I pretty much do as your saying, but I guess my problem may not be the know-how but the frequency of doing or the lack there of.
Old 08-01-2012, 11:47 PM   #6
call me E
TheEplumber's Avatar
Here's one chart. I have better one in my fitter's book but I never use them. I simply measure the fittings.
http://www.engineeringtoolbox.com/np...ads-d_750.html
The cut threads should hand tighten 2 or 3 turns If more it will affect your make up and possibly its seal and like Allen said, total make up is about 3/8 for 1/2" pipe.
I always to measure from center to center of any kind of pipe I'm working with- plastic, cast iron, steel, etc. It's about the only consistent point. For instance, Center of a 3/4 90 to the center of a 1/2 branch of a 3/4 tee. Then you simply subtract the take off of each fitting to arrive at the cut length.
Hope this helps.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 08-02-2012, 04:10 PM   #7
Master Plumber
Javiles's Avatar
WHY?
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 08-02-2012, 10:24 PM   #8
eplumber x2
paintdrying is offline   Reply With Quote
Dropped tiny screw; it's lost RocketGal Electrical 8 04-22-2012 05:50 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
running water pipe to stable rocklobster Plumbing 4 06-13-2010 09:56 PM
water running down waste pipe rav927 Plumbing 5 07-04-2009 10:24 PM
