Loss Of Pressure In Shower This Morning - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2011, 10:31 AM   #1
Loss of pressure in shower this morning
This morning my wife was showering and said the pressure dropped significantly. We've never had a problem with water pressure so this is odd. My first thought was that water must be escaping somewhere. I walked around the house while the shower was on and I didn't find water shooting out of any pipe or hear any water running other than in the drain. I tried the tub (separate) and other faucets around the house and the pressure didn't seem low but it might just be more obvious in the shower. We didn't lose any heat in the water temp and nothing that uses water was running at the same time.
What can I do to further troubleshoot this problem?
frizbplaya is offline   Reply With Quote
Old 02-03-2011, 09:06 AM   #2
KCA
Hello
Hi..
You didn't seem to get any responses so I'll give it a shot..
How many GPM are you getting? Take a 12, or 3 gallon bucket and time how long it takes for the thing to fill up.. a 5 gallon bucket would be to heavy I think..
Older valve @ 50psi = +- 4GPM
Newer valve @ 50GPM = +- 1.6GPM
Newer valve @ 80psi = +- 2.5GPM
You may have some debris in the cartridge... What brand valve do you have?
Hope this helps
:-) Ken
The K.C. Ament CO., Inc.
KCA is offline   Reply With Quote
Heat loss over shower stall John_W Building & Construction 20 02-07-2013 05:02 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Low Water Pressure Delta Single Handle Shower Model 602 rckeagle Plumbing 2 07-24-2009 02:11 PM
water pressure in shower issues sflamedic Plumbing 8 04-07-2009 01:55 PM
New shower valve.. No water pressure? wilson5307 Plumbing 2 03-11-2009 10:10 PM
