Loose Toilet Question (With Pics) - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2012, 12:00 PM   #1
I am stumped! I had a toilet that was loose on the floor, when it shifted too much the bowl would over flow. I decided to replace the wax ring this morning and to make sure what parts I need before heading to the store I tried to unscrew both bolts. Of course the both snapped off.
After removing the toilet I am totally confused. There is no wax ring and tons of corrosion. After breaking away some of the calcium build and corrosion I finally found the flange. The flange wasn't screwed or nailed in, it appears to be set in some kind of plaster. The flange was cracked and broken and the channels on each side for the bolts were solid with plaster. I have chipped away the junk around the flange and pried it off the floor. But it appears there is some kind of metal underneath the old flange. I am going to attach some pics but I am totally confused???where do I attach a new flange?
Loose Toilet Question (With Pics)-image-3752122929.jpg   Loose Toilet Question (With Pics)-image-1512636598.jpg   Loose Toilet Question (With Pics)-image-465924328.jpg
tomberlins is offline   Reply With Quote
Old 10-07-2012, 12:13 PM   #2
Rewards Points: 2,210
Is there access below? Looks like it may be a concrete floor.
There are rings with a gasket that you screw to the floor then wax ring to the toilet perhaps one of them may work?
Can't remember the name maybe someone else will be along who knows the name.
mae-ling is offline   Reply With Quote
Old 10-07-2012, 12:15 PM   #3
It's an off grade house - I've been under near every inch of it and can't imagine that it is concrete.
Old 10-07-2012, 12:28 PM   #4
Rewards Points: 13,260
That metal sticking up is lead, the floor looks like an old mud job.
I use my ossilating saw to cut off the lead so it's even with the top of the hole and use one of these to replace the flange. It gets Tap-Coned to the floor making sure the key holes line up where the new closet bolts are going to go.
http://www.bing.com/images/search?q=...=toilet+flange
Old 10-07-2012, 12:44 PM   #5
Thanks for the reply Joe. I see how that flange will work and I understand about trimming down the lead. What do you mean by "tap-coned" to the floor?
Thank you!!
Old 10-07-2012, 12:49 PM   #6
http://www.concretescrews.com/
Old 10-07-2012, 12:54 PM   #7
Really appreciate the help - my wife is standing next to me and amazed that people are so helpful.
I might come out of this smelling like roses! Well maybe not quite that good
Old 10-07-2012, 02:16 PM   #8
If you own you own home just wait, something will come up to put you back in the dog house real soon, you can count on that. lol
In one month we had the TV poop out, a dimmer switch died I replaced it with a brand new one and it was bad, the distribution box on the septic tank broke and caved in, fan switch in the bathroom went bad.
I spend all day working on other peoples stuff then come home and have to do more. I like it better working on other peoples stuff I get paid for that.
Old 10-12-2012, 06:15 AM   #9
So I bought the device Joe caption suggested and trimmed the lead with a reciprocating saw. Got a new wax ring and got to work...
Problem #1 - the tube that comes out of the bottom of the toilet to go into the drain is too wide to fit into the fancy flange. It just sits on the PVC an inch or two off the floor. So I went back to the big box floor and got a new wax ring and just a plain old flange without the fancy extension...
Problem #2 - the actual drain has a bend immediately below the level of the floor. So that same tube coming out of the bottom of the toilet makes contact with the drain pipe. So with the toilet back in place it rocks just like it did before I took the whole thing apart.
So do I try trim down the tube coming out of the toilet. I am really at a loss here...
Thanks for any help you can provide...
Old 10-12-2012, 08:24 AM   #10
Rewards Points: 2,516
Is this what you are referring to when you say the tube that comes out of the bottom of the toilet??
If so you want to try cutting or trimming that?/ Good luck with that idea. You will definitely be in the dog house then.
hammerlane is offline   Reply With Quote
Old 10-12-2012, 11:11 AM   #11
That's it! But the one on my toilet is much longer. I know it seems like a terrible idea but I don't know what else to do.
Old 10-12-2012, 12:21 PM   #12
Rewards Points: 352
Mnnn, you could replace the toilet with a new Toto toilet.
plumberinlaw is offline   Reply With Quote
Old 10-12-2012, 01:09 PM   #13
I'd like to avoid the $200 for a new toilet...
Old 10-12-2012, 02:06 PM   #14
bbo
you could try to trim it down, then when it cracks, you'll be forced to get a new toilet.
I've heard of people shimming the toilet ( google toilet shims)
you can also use two wax rings ( won't hurt )
bbo is offline   Reply With Quote
Old 10-12-2012, 04:31 PM   #15
So after further inspection I realized that my floor was pretty unlevel (72 year old home). So I did use 2 small pieces of carpenter shims and it worked perfectly.
New problem is the boot that connects the tank to the bowl is leaking now - good grief....
Toilet rough-in question docmattman Plumbing 7 06-21-2011 10:39 AM
Toilet Leak/Backup Question Pittsville Plumbing 12 06-11-2011 12:35 AM
Powder room refresh/ painting -- toilet tank question whataboutj Painting 2 10-02-2010 01:27 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
tile and toilet flange question rbaggett Plumbing 2 11-13-2008 05:43 PM
