Loose Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2009, 04:48 PM   #1
loose toilet
I've noticed the toilet in our new house rocks from front to back a little. The floor is a concrete slab with vinyl flooring. It appears the weight of the toilet and person is being supported by the flange(stub-out). It's not off by much, but I'm afraid it will eventually break. Is there something I can use to ensure the weight is supported by the floor? Epoxy or....?
higgins is offline   Reply With Quote
Old 12-26-2009, 05:04 PM   #2
I'm no pro, but I had a similar problem and was told to use shims. I just shimmed up the toilet with some plastic shims until it was flat and stable and caulked around the gap to make it pretty.
steveo178 is offline   Reply With Quote
Old 12-27-2009, 04:15 PM   #3
Thanks Steve. I figure it's easier to avoid a problem now than fix it later.
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet seat slipping and coming loose. zunebuggy Plumbing 1 09-07-2009 03:43 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
