Loose Sink Strainer - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2011, 02:00 PM   #1
Loose Sink Strainer
I am trying to install a new lock nut on my sink strainer. I used plumber's putty to seal the strainer, but that makes the whole strainer turn, so I am unable to screw the lock nut on. I have tried tying down the strainer, putting weights on the strainer, but no luck. What do I do?
stavner is offline   Reply With Quote
Old 09-08-2011, 02:44 PM   #2
Hi,
they make a tool for that, that you can get at your local home depot or Lowe's. you can also use your imagination and try using needle nose pliers or a coulpe of screwdrivers that someone can hold on the top while someone down below is tightening the strainer nut. the best way is the proper sink strainer tool.
good luck...............tool-man
handyman8494 is offline   Reply With Quote
Old 09-08-2011, 03:14 PM   #3
What tool is that?
Old 09-08-2011, 03:23 PM   #4
You can use a sliding channel lock pliers or lowes has a tool section with plumbing wrenches
The kitchen man is offline   Reply With Quote
Old 09-08-2011, 03:35 PM   #5
It's called a strainer wrench and looks like this;
VIPlumber is offline   Reply With Quote
Kitchen Sink Strainer Nut Falling Off GearHd6 Plumbing 2 02-21-2011 06:58 PM
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 08:47 PM
Kitchen sink basket strainer hkm2 Plumbing 1 08-06-2009 06:44 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Vessel sink fits loose on counter top jam12 Plumbing 3 11-20-2008 05:02 PM
