Loose Pipe Threads - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2007, 06:57 AM   #1
loose pipe threads
This problem is fairly plumbing related. I have a kitchen light with extension rods that screw together. Yesterday my light plummeted until caught by the electrical wires. I tried to screw it back together, and found that the threads on the two joining pieces (basically pipes) are too loose to screw together. You can push them in and pull them apart easily. So now how do I keep my light up and hold the weight of the glass shade?
So here's the big question-- what product do I use to beef up the screw threads and make sure they never pull apart again? I'm afraid most products out there will only lock the two pipes together if the threads already fit properly. Help!
fixitmom is offline   Reply With Quote
Old 10-25-2007, 07:22 AM   #2
Rewards Points: 150
Teflon tape might do the trick.
If you don't plan to disassemble the thing, you could epoxy them togeather.
Or you could drill a thin hole (1/16") through the entire assembly and secure with a finish nail acting as a pin.
scorrpio is offline   Reply With Quote
Old 10-25-2007, 10:56 AM   #3
About 5 wraps of teflon tape should fill the threads enough to keep the rods together. You don't need to worry about it leaking any "juice".
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 06:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
