Loose Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2013, 12:17 PM   #1
Rewards Points: 14
Loose kitchen faucet
I recently installed a Moen kitchen faucet, following the instructions for a single hole sink (see image)
The faucet is designed to rotate, but it keeps coming loose. I have tightened the nut pictured here several times.
I thought perhaps installing a second nut under the first one might keep it from coming loose as the faucet rotates back and forth. Is there a better fix, or did I install it incorrectly?
Thanks,
Mark
veritas is offline   Reply With Quote
Old 02-01-2013, 12:40 PM   #2
DIY staff
Rewards Points: 7,174
Call Moen----Some times the rubber O-ring binds up, that is suppose to allow the thing to swizel---if it's stuck---that nut will come loose----
veritas (02-01-2013)
Old 02-01-2013, 02:06 PM   #3
Roofmaster
Rewards Points: 2,210
Hey mike, what have you been swizzling?
Old 02-01-2013, 02:14 PM   #4
Rewards Points: 14,020
I could be wrong, and I am all the time but I'm not seeing a pivot point on that style faucet. Sure it's not one for a single faucet?
Whats the model #?
Old 02-01-2013, 02:29 PM   #5
Rewards Points: 14
Whats the model #?
It is a CA87010V.
The instructions included steps for both three-hole and single hole sinks, so it is designed for either setup. There's a black plastic ring at the base of the faucet (see first photo). When the nut in the 2nd photo is really tight, I believe the black ring stays in place. However, the nut never stays tight for long, and the ring starts rotating with the rest of the faucet fixture above the sink.
I think Mike is right, and the faucet is supposed to rotate freely on the black ring. There's too much resistance, so the nut below the sink starts loosening each time the faucet swivels clockwise.
I sent a note to Moen with my photos using their contact form--hopefully they have a good answer.
Old 02-01-2013, 02:43 PM   #6
How thick is what your attaching it to?
If you look on the right hand side in the directions that spacer can be used two differant ways to make up for a thiner deck.
http://www.moen.com/shared/docs/inst...s/ins1954c.pdf
Old 02-01-2013, 02:52 PM   #7
Rewards Points: 14
I used Option A for thinner sinks, since the sink is about 1/2 inch thick. Do you think I am just not tightening the nut enough? I thought I was getting it in there pretty good.
BTW, here's a close-up of the black ring I was talking about:
Old 02-01-2013, 02:55 PM   #8
Is that ring a plastic one that was on the base plate for a three hole sink, not just to oring right?
Old 02-01-2013, 03:14 PM   #9
Rewards Points: 14
Ah, I think I know what the problem is. I did not install O-Ring "E", because it is not pictured in the single hole option:
You can see it here clearly, in the three hole option, so I thought it just applied in this case:
However, as I re-exmine step 1, it looks like you are supposed to install O-ring "E" for either option, which I mistakenly did NOT:
Do you think I have re-interpreted the instructions correctly this time?
Old 02-01-2013, 03:22 PM   #10
DIY staff
That's part of the problem----Give it a shot--but I think that faucet has a history of not swiveling well---I recall something----
Moen has a pretty good customer help line---if all else fails--call them.
Old 02-01-2013, 03:23 PM   #11
That would make more since to use that oring.
Old 02-01-2013, 08:34 PM   #12
Plumber & Gasfitter
Rewards Points: 77
99% time the reason a faucet of that style comes loose is because the securing nut was not tightened enough. What tool did you use to secure it to your cabinet/sink?
joeplumber85 is offline   Reply With Quote
Old 02-01-2013, 08:43 PM   #13
Rewards Points: 14
I used the included plastic tool with a screwdriver inserted:
I thought I got it on there pretty tight.
Old 02-01-2013, 08:54 PM   #14
Plumber & Gasfitter
Rewards Points: 77
Those plastic tools they supply are generally garbage, good for getting it snug but never tight. Typically you still need 1 or 2 good rotations with a basic wrench to make sure the faucet doesn't move.
The Following User Says Thank You to joeplumber85 For This Useful Post:
easy kitchen faucet install question adamhodge General DIY Discussions 4 07-04-2011 09:45 PM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
taste of chlorine in water from newly installed kitchen faucet ilyaz Plumbing 4 04-20-2010 03:14 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Can I install a kitchen faucet on Utility sink/tub?? TDRohn Plumbing 4 09-17-2008 12:13 PM
