Old 02-14-2012, 03:14 AM   #1
Loose hot water valve handle
I have replaced shutoff valves before but not the type that is shown in the attached picture. Not sure of the manufacturer or model number. Appreciate any help.
hawaiiboy is offline   Reply With Quote
Old 02-14-2012, 07:40 AM   #2
A set screw is the usual fastener. If there is no visible set screw, the small top flare screws down to the large bottom flare. The bottom tightens the fixture to the top.
Old 02-19-2012, 07:49 PM   #3
Sorry. Still can't see any screws at all. I'm at lost.
Old 02-19-2012, 07:50 PM   #4
Well if there are no screws, how would I take it apart)
Old 02-19-2012, 07:59 PM   #5
can you unscrew the horizontal part of handle off
jaydevries is offline   Reply With Quote
Old 02-19-2012, 08:02 PM   #6
were all on the right track on this one something unscrews??????
Old 02-19-2012, 08:05 PM   #7
Will try to unscrew starting with the handle when I get home. Aloha.
Old 02-19-2012, 08:07 PM   #8
good deal let us know how you make out ....thanks ben
Old 02-19-2012, 08:24 PM   #9
Super Moderator
Likely---the handle is held on by the bell shaped base or the bulged fancy work just under the handle
Old 02-19-2012, 08:34 PM   #10
Experienced
Jackofall1's Avatar
Try this, those are Moen I am almost sure of that Moen T4570PMC Bathroom Faucet Parts
Mark
Old 02-19-2012, 09:18 PM   #11
Mark
Thanks for the blow up picture!
Old 02-19-2012, 09:20 PM   #12
Experienced
Jackofall1's Avatar
Your welcome and good luck.
There is a plastic insert on those that breaks and that is what is likely your issue.
Mark
Old 02-20-2012, 02:16 PM   #13
Hello All. My wife pointed out that I have a Kohler faucet. Well I went online and figure where to find the ID. Anyway it seems I can't unscrew the handle without using a vice grip or a pipe wrench. The schematic does not show it being screwed in. Any more help will be appreciated.
PS. Turned to YouTube but can't find anything there.
Old 02-20-2012, 02:29 PM   #14
Experienced
Jackofall1's Avatar
You could try this, otherwise Kohler has a help line.
http://helptopics.us.kohler.com/ics/...sp?deptID=5712
I could have sworn those were Moen, but I guess they all look the same.
Mark
Old 02-27-2012, 02:01 AM   #15
Mark
Hi Jack,
Are you talking about this? I am having that problem right now.
Thanks.
herman77057 is offline   Reply With Quote
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
hot water check valve? KE2KB Plumbing 7 01-30-2009 02:36 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
