-   -   Loose hot water valve handle (http://www.diychatroom.com/f7/loose-hot-water-valve-handle-133673/)
hawaiiboy 02-14-2012 03:14 AM
2 Attachment(s)
I have replaced shutoff valves before but not the type that is shown in the attached picture. Not sure of the manufacturer or model number. Appreciate any help.
Attachment 45940
Attachment 45941
Just Bill 02-14-2012 07:40 AM
A set screw is the usual fastener. If there is no visible set screw, the small top flare screws down to the large bottom flare. The bottom tightens the fixture to the top.
hawaiiboy 02-19-2012 07:49 PM
Sorry. Still can't see any screws at all. I'm at lost.
hawaiiboy 02-19-2012 07:50 PM
Well if there are no screws, how would I take it apart)
jaydevries 02-19-2012 07:59 PM
can you unscrew the horizontal part of handle off
ben's plumbing 02-19-2012 08:02 PM
were all on the right track on this one something unscrews??????:yes:
hawaiiboy 02-19-2012 08:05 PM
Will try to unscrew starting with the handle when I get home. Aloha.
ben's plumbing 02-19-2012 08:07 PM
good deal let us know how you make out ....thanks ben:yes:
oh'mike 02-19-2012 08:24 PM
Likely---the handle is held on by the bell shaped base or the bulged fancy work just under the handle
Jackofall1 02-19-2012 08:34 PM
1 Attachment(s)
Try this, those are Moen I am almost sure of that Moen T4570PMC Bathroom Faucet Parts
Mark
hawaiiboy 02-19-2012 09:18 PM
Mark
Thanks for the blow up picture!
Jackofall1 02-19-2012 09:20 PM
Your welcome and good luck.
There is a plastic insert on those that breaks and that is what is likely your issue.
Mark
hawaiiboy 02-20-2012 02:16 PM
Hello All. My wife pointed out that I have a Kohler faucet. Well I went online and figure where to find the ID. Anyway it seems I can't unscrew the handle without using a vice grip or a pipe wrench. The schematic does not show it being screwed in. Any more help will be appreciated.
PS. Turned to YouTube but can't find anything there.
Jackofall1 02-20-2012 02:29 PM
You could try this, otherwise Kohler has a help line.
http://helptopics.us.kohler.com/ics/...sp?deptID=5712
I could have sworn those were Moen, but I guess they all look the same.
Mark
herman77057 02-27-2012 02:01 AM
1 Attachment(s)
Mark
Hi Jack,
Are you talking about this? I am having that problem right now.
Thanks.
