Looks Like It's Time For A New Pool Pump; Please Advise! - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2013, 04:19 PM   #1
Rewards Points: 461
Looks like it's time for a new pool pump; please advise!
I need to replace my current 3/4hp pool pump, which is dying but the CA1100 filter cartridge is new in my 15x30 in ground pool with built in over-flow spa (spa blower not currently working).
I'm not sure if I did these #'s correct but I'm need to figure which pool pump & filter I need for the following:
Gallons of Water in Pool 15,187.5 {15x30 x 4.5 avg depth x 7.5 = 15,187.5}
Gallons per hour (GPH) To clean all the water in your pool in 8 hours. 1898.4 {15.187.5 / 8 = 1898.4}
Gallons per minute (GPM) Divide your GPH by 60 minutes. 31.64 {1,898.4 / 60 = 31.64}
Average Feet of Head 26.6' {15' + 45' + 20' = 80' / 3 = 26.6'}
Skimmer 1: 5' + 10' = 15'
Skimmer 2: 5' + 40' = 45' (spa)
Main Drain: 10' + 10' = 20'
I have received the following quotes from local pool guys:
QUOTE 1: (many options)
"First two numbers are pump and filter combined 1hp or 1.5hp/C1750 Filter, then you have filter only with any of the three VS pumps (Variable speed) code compliant. Then there is the Salt generator Hayward is the best in my opinion/priced 40,000 gallon, bigger the system the longer the cell will last.
All these prices are installed any hardware & materials like valves and whip to perform the labor necessary for the completion of the following work needed, tax included.
Hayward MaxFlo Pool pump and Hayward C1750 filter combo: 1hp. $1025.55/1.5hp. $1160.55
Hayward SuperII Pool pump and Hayward C1750 filter combo: 1hp. $1215.75/1.5hp. $1325.60
C1750 Only: $565.60
Pentair IntelaPro VS pump only: $1545.30
Horner Sunrunner VS pump only: $1120.75
Zodiac FloPro VS pump only: $1685.00
Hayward AquaRite salt generator 40,000gal.: $1510.50
QUOTE 2: (2 options)
Hayward MaxFlo Pool pump 3/4hp. $335 + $85/hr labor
Hayward MaxFlo Pool pump 1hp. $353 + $85/hr labor and Hayward C2000 filter $355 + $85/hr labor.
All thoughts and advice are greatly appreciated, thank you!
a1481155 is offline   Reply With Quote
Old 04-06-2013, 07:51 PM   #2
Rewards Points: 582
C1750 Only: $565.60
ok whats the problem you look like you did the right thing ,,got prices from local contractors ....select one then your done..
The Following User Says Thank You to ben's plumbing For This Useful Post:
Javiles (04-08-2013)
Old 04-08-2013, 06:52 PM   #3
Rewards Points: 461
My apologies to bother everyone with such a stupid question, thanks!
Old 04-08-2013, 06:58 PM   #4
Rewards Points: 582
no iam sorry if i offended you ...but really you did what your suppose to do ....and remember the only stupid question is the one not asked.....thanks for visiting us...please do come back...ben sr
Old 04-19-2013, 03:27 PM   #5
Rewards Points: 461
No problem...I just don't know what size pump & filter are appropriate for the size of my pool. I was quoted anywhere from 3/4hp with no filter upgrade to 1.5hp to Variable Speed with filter upgrades from C1750 to C2000 and systems with salt. I'm also looking for experiences with the different makes & models over time.
FWIW, I'm looking for an Automatic Pool Cleaner to add to the system as well. THANKS!
Old 08-07-2013, 04:14 PM   #6
Rewards Points: 461
Still seeking guidance on what type & size replacement pump and/or filter are appropriate for my pool, if anyone can help.
Thanks!
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 05:15 AM
pool pump and timer fried??? illuminate Electrical 4 05-21-2012 11:24 AM
Pool pump, cleaner, light wiring issues tulsajeep Electrical 4 06-05-2011 06:56 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
GFI Breaker & pool pump mitchman333 Electrical 7 05-08-2006 05:32 PM
