Looking For Pipe TAP To Chase The Threads - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2013, 04:35 PM   #1
Rewards Points: 278
looking for pipe TAP to chase the threads
I wanted to clean out the threads on this tee, there is some slight corrosion and crud.
it's a 1/2" fitting, Is it a 1/2" NPT thread?
On the other hand seems like a $20 tap may be over kill, is there a way to clean up the threads well, e.g. using another male fitting with slots cut into it. A PVC fitting is going to the bottom and currently from the plug I installed I know it is not leaking, maybe cutting the threads will make it worse?
DIYGST is offline   Reply With Quote
Old 01-08-2013, 04:51 PM   #2
Rewards Points: 13,300
A pipe thread will fix it but why fix it.
Those old steel fitting will always leak and start to close up on the insides.
Should have been replaced with new lines.
Old 01-08-2013, 07:31 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
Taps are kind of spendy for one job. Try a brass nipple or steel nipple- run it in then remove it and check the threads. Also, a small copper fitting bush chucked into a drill works.
Old 01-09-2013, 10:10 AM   #4
Plumber
Your kidding right ?
Thats a $2.00 part, why in the world would you waste that much time and risk a leak for $2.00 ?
DidIDoThat is offline   Reply With Quote
What's a chase cover? Rockford Roofing/Siding 1 07-25-2012 08:43 AM
What is a chase cover? Rockford General DIY Discussions 0 07-24-2012 09:52 AM
Posting to old threads rusty baker Site Help and Suggestions 3 03-20-2011 08:07 PM
Flashing decking around fireplace chase kwerk Building & Construction 0 10-29-2010 12:48 AM
Decorative chase for masonry chimney and radon vent? Badfish740 Building & Construction 1 05-03-2010 07:51 PM
