Looking For Help On Laundry Room Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2010, 08:13 PM   #1
Looking for help on Laundry Room Plumbing
I am about to replace my old washer, and I will need to rearrange the laundry room to accomodate the larger front loading machine. Piping layout is tricky, and I am attaching a diagram of how I would like to do it - provided it meets code, of course.
I think my concern is whether I am ok to use this trap arrrangement - but I would welcome any advice if there are any other code restrictions I have ignored!
I am in Ontario, Canada - let's just say we are pretty conservative but not that much different ... an example is the distance from the trap weir to the vent must be no more than 5'.
Thanks for any help
Guy
GuyBooth is offline   Reply With Quote
Old 06-08-2010, 08:53 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I know zero about canadian plumbing code.
I'd check to make sure you are allowed to serve two fixtures with one trap. That is not allowed here.
Journeyman Plumber
Old 06-08-2010, 10:15 PM   #3
Thanks for the feedback Alan.
I know that a more usual layout is for the sink to drain vertically into the trap, with the standpipe feeding into the vertical drop between the sink and the trap. I've seen that layout in several places, in different states, and I do know that that layout does meet code in Ontario.
Tags
drains , plumbing
Laundry Room Drain Set-Up - is it okay? bmb2m9 Plumbing 1 02-02-2010 10:49 PM
Options for partition in laundry room...? butterdog Building & Construction 1 12-08-2009 12:29 AM
replace faucet in laundry room nextbond Plumbing 3 09-15-2009 10:18 PM
Adding a 1st Floor Laundry room Profane Plumbing 3 01-25-2008 01:19 PM
stabilizing floor in laundry room waterlily_girl Carpentry 3 03-02-2006 12:59 PM
