Looking For Fittings Need Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2012, 10:00 PM   #1
Rewards Points: 52
Looking for fittings need help
I need 2 3/4 inch 90 degree brass elbos. They need to be threaded on one end and copper sweat on the other.
This guy on eBay sells in 10 units. If you search for ebay item 370513850775, you will see exactly what I am looking for.
Thanks for any help. Home Dumpo only had them in 1/2 inch.
digitalplumber is offline   Reply With Quote
Old 11-20-2012, 10:19 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
google 3/4 mip x copper 90, I found some that way. Or you could try a local plumbing supply house.
Could you use a copper mip with a copper street 90 attached to it?
Old 11-20-2012, 10:22 PM   #3
Rewards Points: 52
Probably, but I have limited space for the new Kohler Valve and was wanting to limit fittings and joints, reduce chance for leaks!
Old 11-20-2012, 11:18 PM   #4
joed's Avatar
Rewards Points: 12,016
This place has them but it says 'not for potable drinking water'
http://www.plumbingsupply.com/copper.html
Old 11-20-2012, 11:23 PM   #5
Rewards Points: 52
Thanks, but thats not what I am looking for. Looks like I can get them at Grainger for a fair price.
http://www.grainger.com/Grainger/NIBCO-Elbow-5P157
Old 11-20-2012, 11:32 PM   #6
Rewards Points: 13,300
Why do they need to be brass.
Any box story or local plumbing supply will have copper fittings like that.
Old 11-20-2012, 11:38 PM   #7
Rewards Points: 52
They don't. I just thought brass into brass would be a better long term fit. Plus I never saw a 3/4 threaded 90 copper one end and solder other end.
digitalplumber is just a name for use here, I am not a plumber!
Old 11-21-2012, 12:14 AM   #8
http://www.buyhardwaresupplies.com/?...emNumber=41337
Old 11-21-2012, 12:22 AM   #9
Rewards Points: 52
I need a 3/4 Connection C x MNPT elbo
Old 11-21-2012, 02:47 AM   #10
Plumber
Rewards Points: 452
You could take your valve back and exchange it for one that has sweat connections rather then iron pipe. That way you'd eliminate any threaded joints and could use st 90's on the valve.
