Looking For 3/4" Rubber Tapered Barbed Pipe Fitting For Two Female PVC Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2012, 09:44 PM   #1
Looking for 3/4" rubber tapered barbed pipe fitting for two female PVC pipes
I'm having a heck of a time finding the part I'm looking for either at my local home improvement warehouse or online.
I need to fit together the 3/4" inner diameter PVC drain pipe from my air conditioner to the drain pipe that it was connected to (dumps to household plumbing). The pipe was sheared off due to physical force and it would cost me too much to replace the inner drain pan of the air conditioner. There's no water pressure to speak of, so leaks are not a concern. The drain emits about one drop per second at its maximum rate (that I've seen).
If I had a soft rubber, tapered, barbed, 3/4" inner diameter female-to-female pipe fitting, similar to the product at http://www.grainger.com/Grainger/LASCO-Coupling-6MM76 (picture attached), I'd be good to go, but I just can't find one made of soft rubber. I tried a hard plastic one but I couldn't get enough leverage in the tight space to get it into the plastic piping. Besides, I think the plastic piece is really for connecting two female flexible hoses together, not PVC piping.
Anyone know where I can find such a fitting?
Thanks,
Matthew
matthewadams is offline   Reply With Quote
Old 09-10-2012, 09:58 PM   #2
Rewards Points: 12,856
If it's really PVC pipe you have, PVC fitting go on the outside of the pipe not the inside. If it was on the inside it would restrict flow and cause a build up where molds going to set in and block the pipe.
Can you post a picture of what you have.
If you think a reguler coupling will not work, try a hubless connector. Nothing more then a rubber tube with 2 hose clamps.
The one you posted a picture of is for black Poly pipe or rubber hose. Not a hard breakable pipe like PVC.
Old 09-11-2012, 12:00 AM   #3
if you want something that you don't have to glue try one of these and you can take it apart in the future if it clogs. they are sized by the inside diameter of the pipe by the way.
http://www.homebuilderwholesale.com/...-Coupling.html
Old 09-11-2012, 11:13 AM   #4
Good idea from both of you, but they won't work. The pipe sheared off too close to where it exits the air conditioner housing. See pic. Rotate picture 180 degs -- t's upside down for some reason.
I think a small funnel, only a couple of inches tall, might just be my best option.
Looking for 3/4" rubber tapered barbed pipe fitting for two female PVC pipes-img_3150.jpg
Last edited by matthewadams; 09-11-2012 at 11:15 AM. Reason: Photo was turned upside down.
Old 09-11-2012, 11:20 AM   #5
Pic still being rotated upside down by forum software.
Old 09-11-2012, 11:22 AM   #6
Image now rightside up. The pipe on the left is the drain pipe that was connected but was sheared off.
Last edited by matthewadams; 09-11-2012 at 11:24 AM. Reason: better response w/pic properly rotated.
Old 09-11-2012, 11:25 AM   #7
Looks like you snapped off the threads and there still left in the hole.
The right way would be to remove what's left of the threads, clean up the treads with a wire brush the shape of a tooth brush and in replace that broken Street elbow.
Old 09-11-2012, 11:38 AM   #8
Careful when you say I did it. I didn't.
Anyway, the elbow doesn't actually have any threads. If I could somehow glue to the two pieces back together such that the bond forms a seal, I'd be back in business.
Any glue/bonding recommendations?
Old 09-11-2012, 11:41 AM   #9
Rewards Points: 3,362
Thats an easy fix,just get an easy out from home Depot and remove the threads that are still in there,and your good to go.
Canarywood1 is offline   Reply With Quote
Old 09-11-2012, 11:48 AM   #10
@Canarywood1, there are no threads...
Old 09-11-2012, 12:03 PM   #11
If there's no threads then where did that street elbow go that sitting right next to the hole?
http://www.bing.com/shopping/genova-...M=EGCA&lppc=16
Old 09-11-2012, 12:16 PM   #12
Not sure. You're seeing what I'm seeing. Here are two more pics, this time of the elbow.
Looking for 3/4" rubber tapered barbed pipe fitting for two female PVC pipes-img_3151.jpg   Looking for 3/4" rubber tapered barbed pipe fitting for two female PVC pipes-img_3152.jpg
Old 09-11-2012, 12:20 PM   #13
Look at the fitting where the threads are, see how jagged it is?
I can see the threads up inside the hole were it was screwed into.
You need a new street elbow, short piece of the same size PVC and a PVC coupling to rejoin the pipe after the old elbow is cut off.
Old 09-11-2012, 04:14 PM   #14
I beg to differ with you,like Joe said the threads are in there and the only way your going to fix it is to remove the broken off piece thats still in there and put a new street el in.
Old 09-11-2012, 05:42 PM   #15
Rewards Points: 438
If you don't have an easy out, and many DIY ers don't, the broken piece in the pan can be removed by splitting it in 2,3 or possibly 4 pieces using a hack saw blade and prying the sections out. I would probably use a saws all but that can be a little risky and one can't feel when the threads are reached like with a hand held blade. Sometimes good things take a little longer.
SeniorSitizen is offline   Reply With Quote
Tags
3/4 , fitting , pipe connection , pvc , rubber
Pipe insulation: Foam, Rubber, Other? IckesTheSane Plumbing 40 03-21-2016 07:57 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
How to clean a PVC waste pipe from rubber washer remains? sukhenkoi Kitchen & Bath Remodeling 3 03-04-2011 11:10 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 10:50 PM
