Old 12-08-2012, 06:50 PM   #1
longer 4" abs run - how to maintain slope?
I'm running a 4" abs pipe for about 50 feet. How does one maintain the 1/4" per 8 feet slope? Are there any methods or ways to do this easily? It's an old house built in the 1930's with additions made in the 80's and the foundations sunk in some places. So everything is a little off and improvised and maintaining distance from the joists is not an option. If I slope it a little bit more in some places what are the implications? I'm thinking about eyeballing it and allow for a gentle slope. Can this be trouble or is this fine?
jackwashere is offline   Reply With Quote
Old 12-08-2012, 06:56 PM   #2
call me E
TheEplumber's Avatar
They make levels that have graduated vials for 1/4" per ft. Or you can tape a shim on one end of a level.
Also, if grade is hard to get, You can run 4" pipe at 1/8" per ft.
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (12-08-2012)
Old 12-08-2012, 07:23 PM   #3
Great idea! I have a 4' level and I can create a 1/8" shim. That should do the trick.
Old 12-08-2012, 07:26 PM   #4
call me E
so the shim at the end of the 4ft level should be 1/2" which = 1/8" per ft.
ben's plumbing (12-08-2012)
Old 12-08-2012, 07:42 PM   #5
In case you mis-understood TheEplumber. You'll need a 1/2" shim on your 4' level for minimum slope.
Fairview is offline   Reply With Quote
Old 12-08-2012, 08:40 PM   #6
Right, 1 inch per 10 feet.
Old 12-08-2012, 09:06 PM   #7
A "Handy Husband"
rjniles's Avatar
No 1" per 8'
Coastal South Carolina
rjniles is offline   Reply With Quote
Patio slope both ways? Joe442 Concrete, Stone & Masonry 6 09-20-2012 09:37 PM
hollywood slope help perfectionroof Roofing 0 09-16-2012 11:29 PM
Door issues leveling 1 degree slope in room Woodbury Carpentry 1 08-07-2012 07:24 AM
Pipe fittings and slope slkarns Plumbing 6 04-11-2012 10:06 PM
Is it necessary to level a concrete floor with a slope of 1" / 13.5 feet ? johnnewengland Remodeling 4 03-19-2012 05:42 PM
