Old 12-06-2012, 12:28 PM   #1
Question
long HW Run
i have a 3 story facility, HWH is on 1st level and supplies 3rd level restrooms. We cannot get HW to the 3rd level. there is No HW return line,only supply. due to the cost of installing a new return line what other options do i have to get HW to 3rd level restrooms
cbrow is offline   Reply With Quote
Old 12-06-2012, 12:49 PM   #2
long HW Run
Not following you, why would you need a return on a water heater?
Old 12-06-2012, 12:52 PM   #3
long HW Run
for circulation purposes. the run is long so water temp decreases by the time it reaches user source. In most facilities we have a return line with circ pump so HW is constantly traveling. at this facility we have no return line. is there anything that can be installed to reheat water as it travels further away from water heater to maintain set temperature?
Old 12-06-2012, 12:55 PM   #4
long HW Run
Put a small water heater on the 3rd floor.
info2x is offline   Reply With Quote
The Following 2 Users Say Thank You to info2x For This Useful Post:
cbrow (12-06-2012), joecaption (12-06-2012)
Old 12-06-2012, 01:11 PM   #5
Special User
long HW Run
You can get recirc systems that use the existing cold for the return, but those are generally for single family residences -- I don't know if code allows it for commercial/industrial settings (my guess is, probably not).
Yup.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is online now   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
cbrow (12-06-2012)
Old 12-06-2012, 01:32 PM   #6
Master General ReEngineer
Bondo's Avatar
long HW Run
Ayuh,... Or even "Point of Use" water heaters...
Long Handled weeder KE2KB Landscaping & Lawn Care 0 06-24-2010 07:10 PM
How long between tiling steps? ptraz Flooring 4 03-12-2010 08:13 PM
How long does it take for Aura to cure? slickracer Painting 8 01-03-2010 05:58 PM
Why long lasting bulbs go out of service quickly? art2670 Electrical 8 10-27-2009 09:10 AM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 01:37 PM
