Old 09-03-2006, 09:18 AM   #1
Loft Tank Question
I just took a look at my loft tank because I had a nasty experience some time time ago when the ball valve snapped off and I had water cascading ( through the overflow) thank goodness but my next door neighbour had the same problem a few weeks ago but she wasn't so lucky, it flooded her house. Anyway, I digress The ball valve looks ok but the water and the tank are disgusting. It is covered on all sides so can't see why it's full of dust and other things! Should it be like that?
hansi is offline   Reply With Quote
Old 09-03-2006, 09:39 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Loft Tank Question
What you see comes from the water, it won't hurt anything, you could turn the water off, clean out the tank and this will give it a clean start.
Ron The Plumber is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 12:11 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Question About Bolting Wood Together for a Loft ArcticRSXS Building & Construction 15 09-16-2005 05:42 PM
