Old 12-02-2011, 10:13 PM   #1
Location of shower shut offs
Hi,
I will be replacing my shower and I want to install shutoffs. I would like to put them in the wall behind the faucet because there is nowhere else they can go. The shower is on the other side of the wall behind my stove. I.e. kitchen and bath are divided by a wall. Is there any problem with making an access panel behind the stove to operate the shut offs?
Thanks,
W
Wapmiasomey is offline   Reply With Quote
Old 12-02-2011, 10:24 PM   #2
Sounds like a good idea
Service plumber is offline   Reply With Quote
Old 12-02-2011, 10:30 PM   #3
yes agree with service plumber good idea they make premade plastic access panels really works great...
Old 12-02-2011, 10:32 PM   #4
Super Moderator
That will work---also consider a mixer with built in shut offs--they make changing the cartridge easy--the tiny shut offs are part of the mixer and accessible when the cover plate is removed---Mike---
ben's plumbing (12-02-2011)
Old 12-02-2011, 10:36 PM   #5
thats even a better idea from mike they make diverters with stops just as mike describes ....always thinking around here ...thanks mike
Old 12-02-2011, 10:42 PM   #6
Super Moderator
I'm lazy----it's less work to get it all done with the torch---
The definition of LAZY is the love of ease.
Old 12-02-2011, 10:46 PM   #7
I know what you mean...FATHER IN LAW,..ALWAYS SAID ITS GREAT TO WORK AT RESTING AND THEN REST AFTER IT.... WOULD THIS BE A DEFINITION OF L..A...Z..Y...HA HA BEN
Old 12-03-2011, 12:44 AM   #8
Thanks for the help guys!
Old 12-03-2011, 07:23 AM   #9
raylo32's Avatar
Great info guys. Learn something new here almost every day. If/when I ever need to replace mine I'll look for a shower mixer with the shutoffs.
I have no access panels or shutoffs on my tub faucets either. If I ever have trouble with those and I can't find a cartridge quickly I guess I'll be busting out tile. :-/
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
oh'mike (12-03-2011)
location of bath switches/ how far from shower mazey Electrical 2 06-29-2011 02:27 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 07:43 AM
shock in shower tbwoods Electrical 64 07-23-2009 12:26 PM
Shower Dripping Hot Water, Should I Shut Off Emergency Oil Burner Switch? bman46 HVAC 1 10-02-2007 03:04 PM
