Location Of New Septic Field - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2010, 08:17 PM   #1
location of new septic field
We have our 40 year old septic field right in front of the house. To the left is a driveway and trees. A river runs behind the house. to the right there is a road. My question? Were we to have to put in a new septic field, where would we put it? Can you put a new one in the place of the old one (unlikely)? Or, since we do have space beyond the septic field, is it possible to run a long drainage pipe through the old septic field into the new one? How long can a spetic drain pipe to field be? thanks for any info.
rkibler is offline   Reply With Quote
Old 10-04-2010, 09:31 PM   #2
HVAC / Plumbing
Depends on where you live. Health dept. tells us where we can & can't install septic tank / field lines
kenmac is offline   Reply With Quote
Old 10-04-2010, 09:51 PM   #3
Owner
LateralConcepts's Avatar
Same here. Local health department has jurisdiction on where.
I'm assuming city sewer is not available then?
Why are you replacing the drain field?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 10-04-2010, 10:08 PM   #4
are you replacing the septic tank, or the leach field? or both?
1910NE is offline   Reply With Quote
Old 10-05-2010, 12:12 AM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
have you had a perc test done to see what you need for laterals?
plummen is offline   Reply With Quote
Old 10-05-2010, 01:55 AM   #6
Long-Time DIYer
Mike Swearingen's Avatar
If you do not have room for another new conventional septic drain field, then there are more compact alternatives that can be approved by your local Health Department. As noted, they are usually the ones who call the shots on all of the above.
Here, they don't do the old perc tests anymore. They take 3' deep soil samples around the yard and then custom design a septic system based on your specific soil type.
If you're having problems, the first thing to do is to call them to do an inspection and issue a repair permit.
Here, a new inspection is $225 and the permit, if it passes, is another $50, which is good for five years. A repair permit for an existing system is free. This varies greatly all over the place.
Call your local Health Department. You don't want to do anything without a permit and inspection, which is required in any case. They can answer all of your questions.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
How do i fix/install septic tank drainage field? vcordon Plumbing 10 06-15-2010 10:20 PM
Septic Drain Field ekulrenlig Landscaping & Lawn Care 16 04-27-2010 09:59 PM
Problem with septic drain field Patriot_RAM Plumbing 7 04-21-2009 02:55 PM
Septic Newbie Needs Advice flyboy Plumbing 5 04-06-2009 06:05 PM
