Location Of Expansion Tank? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2010, 10:12 AM   #1
Rewards Points: 272
Location of expansion tank?
I'm going to install an expansion tank in my plumbing system and all of the diagrams I see mention it being placed on the cold line bewteen the HWT and the PRV. Unforunately for me this is not an ideal location due to some duct work. Would it be okay to place the tank downstream of the HWT and my faucets? Seems like it should be okay to me because pressure is pressure but I wanted to ask first.
In my diagram I'd like to place it in location "B" instad of the recommended "A" location. Will this work?
speedster1 is offline   Reply With Quote
Old 12-18-2010, 10:24 AM   #2
unless your expansion tank is rated for hot water, it should be located on the cold water line. Right before the water tank is ideal, but you can put it in a little way away from it. Also, you can plumb it in with a tee and extend it away from the ductwork... just make sure the tank is supported
the_man is offline   Reply With Quote
Old 12-18-2010, 10:43 AM   #3
Rewards Points: 272
I do plan on putting it on the cold water line. Just not between the hwt and prv. I want it in location B instead of A
Old 12-18-2010, 11:22 AM   #4
Licensed Master Plumber
anywhere in the cold water line will work.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 12-18-2010, 12:40 PM   #5
you just have to be sure there is not a valve between the expansion tank and the water heater, at least that is the code.
Work4living is offline   Reply With Quote
Old 12-18-2010, 01:26 PM   #6
Owner
LateralConcepts's Avatar
Um no. There needs to be a shut off valve in the cold water supply. Before the expansion tank is ideal for servicing.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 12-18-2010, 01:45 PM   #7
The valve is to be located so as to not seperate the heater from the expansion tank. i.e. if you do tank then valve then heater, and the valve is closed seperating the tank from the heater, the system is no longer protected by the expansion tank.
Old 12-18-2010, 03:40 PM   #8
When the city installs new water service they now typically install a meter/backflow preventer/expansion tank combination. There is a shut off before the tank, however if you are just installing a tank, it can go anywhere in the cold water line. If you need to service or change it you can shut off the house main. Lets not over complicate the easy.
Old 12-21-2010, 03:50 AM   #9
Rewards Points: 272
Okay that all makes sense. I didn't think it would be a problem but I wanted to check and be sure. Thanks.
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 03:09 PM
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 01:12 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
Expansion tank location?? rcassidy HVAC 4 10-06-2009 09:01 AM
Installing new expansion tank ted schumm HVAC 2 07-19-2009 09:49 PM
