Location Of Cold Water Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2009, 03:51 PM   #1
Unhappy
location of cold water shut off valve
I' m attempting to put in a new faucet in my bathroom. I shut off the cold water valve in the bathroom and the water stoped running.
When I attempted to take off the supply valve line-water started spurting out from there and would not stop.
I went back down in the basement and attempted to shut off as many valves as I can and still water is coming out.
So my question is: How do I cut off the water completely and where is this valve located?
ant2754 is offline   Reply With Quote
Old 06-07-2009, 04:22 PM   #2
biggles's Avatar
the silver valve on the wall(1 hot 1 cold) under the sink has the house water pressure on it(in the wall) the water stops from that shut off up to the faucet
Old 06-08-2009, 08:16 AM   #3
If you are removing the supply valve from that faucet, you may need to turn off the whole house water at the meter. You could then replace the supply valve and turn it off until you are finished with the faucet install. There would still be water laying in the lines so you may want to drain it down through an outside faucet since they are usually the lowest point.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 12:44 PM
