Locating Water Main Inside A Home - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2011, 10:53 PM   #1
locating water main inside a home
We want to install a water softener and filter for the entire home. How do we locate the water main for hookup? Our house is on a slab, main water shut off is at the street. Water heater is in the attic but the water main splits before going to the water heater. Please help.
lollypol is offline   Reply With Quote
Old 08-05-2011, 10:59 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Where's the water meter and what style is it?
XXX
Old 08-06-2011, 08:07 AM   #3
Its located near the street in a box in the ground. That's also where our main shut off valve is.
Old 08-06-2011, 09:56 AM   #4
Too Old
Just a guess but if you fallow the supply line on the heater you will see it coming out of the top plate, that should give you a location where it comes up the wall from the slab.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 08-06-2011, 10:05 AM   #5
Ok we followed the cold water and hot water lines from the attic down into the house where it ended up between the master bath shower and bathroom closet. Coming out of the slab are 3 copper pipes. The middle pipe goes straight up to the water heater. Breaking off from that pipe are 2 others that go back down into the slab. I'm thinking one of these is the main. Yes? But which one?
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
