Old 02-09-2011, 11:51 AM   #1
Locating Main Drain Line in Basement
I'm trying to locate my main drain line under my slab to add a bathroom in the basement. Attached is a .pdf showing the basement layout with plumbing stack locations. A-D all represent plumbing stacks coming down from the first floor fixtures. Location E is a cleanout at the basement floor level with no other plumbing attached.
From my research, I'm guessing there isn't any exact science to determining the underground layout. Anybody have any ideas or guesses as to what's going on?
Thanks in Advance.
koz123 is offline   Reply With Quote
Old 02-09-2011, 12:30 PM   #2
A few more pieces of information that you may want to include.... Municpal waste or septic? Where is the street or the septic field? Have you checked the perimeter, outside, for a cleanout? Have you tried running water upstairs, and listening for it in the basement?
Old 02-09-2011, 12:42 PM   #3
Dexter,
It's municipal waste with the street closest to the wall that "E" is on. I've done quick visual checks for outdoor cleanouts and haven't found anything but I haven't dug or anything like that.
Old 02-10-2011, 04:35 PM   #4
I would take a guess and say that the main drain line leavs the house right where the clean out (E) is. I would then guess that (A) and (B) are on one straight branch that Y s up just inside the house of (E). I would then guess that (C) goes straight to (E) with (D) Y ing up somewhere between half way (C) to (E) and (E).
Keep in mind I am a CPA that dabbles in home improvement.
B
Beepster is offline   Reply With Quote
Old 02-10-2011, 08:23 PM   #5
i would say the building drain exits at point e too. take the cap off the cleanout, grab a flashlight, and have someone flush a wc. look down the cleanout and see if flow does toward the foundation
the_man is offline   Reply With Quote
Old 02-10-2011, 09:41 PM   #6
Tileguy
Bud Cline's Avatar
I would say you should call your local building inspection office and have them locate it for you. They have tools for this purpose.
Old 02-11-2011, 10:41 AM   #7
Owner
LateralConcepts's Avatar
Search for a local company that does sewer line video inspections and locates. That's all I do. Simply run a camera down the main line, it sends off a signal to a locator above ground (slab), tells you the exact depth and location.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
De-soldering main water line MikeKy55 Plumbing 15 01-29-2011 02:39 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General Discussion 13 12-01-2010 06:42 AM
Basement bathroom sink drain line on a slight upwards slope an issue? dtran Plumbing 7 01-10-2010 06:05 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
Main drain line lmanwarren Plumbing 1 04-06-2006 01:32 AM
