Live And Learn - Smelly Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2010, 12:15 PM   #1
live and learn - smelly bathroom
I tried but might have failed but at least I tried.
I built a new master bath from scratch installing a shower, vanity sink and toliet. All work fine, no leaks, good drainage and all have traps. The vents are currently plugged off with rags just because I haven't drilled the pipes through the roof yet. Wife say's this is the problem - I say the traps prevent odors from backing up and the vents are not the problem -BUT the bathroom has a "sewer odor" coming from somewhere - not all the time ??? It is driving me nuts because logically there is no way this odor should enter the room due to the traps.
Where can I look - any ideas? As a foot note, the odor usually comes when something is used... shower sink or toliet, any and/or all.
thanks for your thoughts
tntgarv is offline   Reply With Quote
Old 02-28-2010, 01:01 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
have you got water in all the traps? maybe your rags are getting sucked down the vent enough to let sewer gas get by them
plummen is offline   Reply With Quote
Old 02-28-2010, 01:19 PM   #3
thanks for the though plummen, the vent lines are not even in the room (already routed to the attic) and the rags are still where they should be so I don't think that's the issue. Also, yes all traps hold and have water in them.
Old 02-28-2010, 01:30 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if your vents are plugged, the system will draw air from somewhere. That somewhere is often through the trap of another drain. As a result, you can end up with a dry trap.
Old 02-28-2010, 01:33 PM   #5
plummen's Avatar
base of toilet tight?
Old 02-28-2010, 01:38 PM   #6
base of toilet is good. the idea about tight vents and sucking air though a trap leave it dry is something I will look at.
thanks
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 11:28 PM
Retiree--Wants To Learn!! Harry1992 Introductions 1 06-02-2009 01:36 AM
