#1 |
Weekend Builder
Little hot water in shower, rest of house OK
Hi,
We moved into our place 5 years ago and in the MBR shower there is very little hot water. In fact, some of the streams seem actually cold! . The rest of the house has HOT HOT water.It is a model (no name) with one lever, off is in the 6-o'clock position, and you turn it counterclockwise to make it hotter. Here is a similar picture to ours. WHAT CAN I DO! |
#2 |
HVAC / Plumbing
Don't know hoe new it is...Has it always been like this ? The newer ones have an anti scald feature that can be adjusted
#3 |
I betcha the mixing valve is worn out/clogged or otherwise not functioning properly.
#4 |
if you remove the handle and cover you will likely see a piece of plastic that prevents the handle from being turned to the full hot position remove that plastic and youll be good to go
those handles should turn almost 360 degrees Last edited by kennzz05; 04-04-2009 at 05:01 AM. |
| Display Modes | |
| Water dripping in the shower??? | Sellncars | Plumbing | 4 | 12-05-2009 09:07 PM |
| Luck warm water to the shower... Help | bwendt | Plumbing | 2 | 03-02-2009 01:23 PM |
| Insane water pressure in shower!!! | Sarah24 | Plumbing | 5 | 12-09-2008 06:27 AM |
| (Water Heater MYSTERY) Hot water out from dead tank with cold water in it? | Inayity | Plumbing | 6 | 07-14-2008 09:36 PM |
| Shower for Boat house | ckornbau | Plumbing | 6 | 01-08-2007 11:47 AM |
