Old 06-04-2010, 09:25 PM   #1
Little Giant 8-CIA Sump Pump Operation
This pump apparently comes on when the water level is 7-10" in height, but from which point on the pump?
smata67 is offline   Reply With Quote
Old 06-07-2010, 08:47 AM   #2
Here is the spec sheet on your pump, it uses a non-adustable pressure switch inside the housing of the pump. Pump on at 7"-10", pump off at 1"-4". Check the spec sheet for the location of the pressure switch, I hope this answers your question.
http://www.lgpc.com/ProductFiles/SpecSheets/995209.pdf
The Engineer is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 49 02-27-2011 02:42 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Sump Pump french drainage issue HomeDIYslfr Plumbing 1 05-16-2009 01:21 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
