Liquid And Smell In New Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2013, 06:05 PM   #1
Rewards Points: 282
Liquid and smell in new pex
While running my new pex for waterline, I cut a section and about an eighth to quarter cup of thin clear liquid poured out that smelled like acetone or paint and was kind of sticky. Is this anything to worry about?
dgfit is offline   Reply With Quote
Old 08-30-2013, 06:08 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
Did you taste it?
Never seen it before in PEX
Old 08-30-2013, 06:10 PM   #3
Rewards Points: 282
Originally Posted by TheEplumber
Did you taste it?
Not yet and dont want to once I open the valves. May have to find some taste testers
Old 08-30-2013, 06:29 PM   #4
Rewards Points: 14,306
I've installed 100's of ft. of Pex and never once saw or smelled anything in it.
If I did I sure would not just go ahead and install it.
Old 08-30-2013, 06:39 PM   #5
Rewards Points: 282
I was joking above - it is not installed. Leaves me hi and dry for this three day weekend.
Old 08-30-2013, 07:04 PM   #6
Rewards Points: 2,106
I would return that pipe.
Ghostmaker is online now   Reply With Quote
Old 08-31-2013, 04:13 AM   #7
Any box store will have 100 ft. rolls of it, why loose 3, days?
Old 08-31-2013, 06:39 AM   #8
Rewards Points: 282
I had it delivered originally because the only local source didn't have enough. But I checked last night and found they restocked so I should be good.
Old 08-31-2013, 10:34 AM   #9
Rewards Points: 282
Ok - exchanged for some new rolls
Old 08-31-2013, 08:56 PM   #10
Rewards Points: 446
Got an air compressor? I'd blow those new coils out before I even brought them in the house.
Kind of scary if the manufacturer's quality control on foreign material in a water supply item isn't any better than that.
old_squid is offline   Reply With Quote
Old 09-08-2013, 08:46 AM   #11
Rewards Points: 282
The rolls I got above were fine, but I just went and got some more rolls of Pex (yeah I underestimated), and it too has the same smell (but no liquid). The pipe before was made in December of 2012, and this pipe was made in August of 2013. After some more searches on the web I find other references to smell in Pex not unlike mine and it seems to indicate it will flush out. It also seems to indicate that PEX-B is smellier than PEX-A.
I have to believe PEX-B is widely used. I guess I'm just going to move forward with it and if it doesn't go away after use then I will rip it all out and replace with PEX-A.
Old 09-10-2013, 10:00 AM   #12
Rewards Points: 131
I installed over 500' of PEX-b and none of it had any strange odors.
HitLines is offline   Reply With Quote
Sewage type smell coming from bathroom shower drain majorchamp Plumbing 29 06-25-2012 10:08 AM
Getting rid of that animal smell. JustaFramer Flooring 9 09-17-2006 09:26 PM
