Lingering Sink Strainer Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2012, 05:23 PM   #1
Lingering sink strainer leak
A little background here:
I acquired an older mobile home and am in the process of making it livable.
One of the problems I quickly encountered was that the sink strainer leaked like a sieve.
I pulled the strainer out, used silicone around the sink hole (plumbers putty said not to use on plastic and my strainer is very much plastic) and I havent had a leak in that area since.
The problem lies in the small coupling that comes up and screws onto the bottom of the strainer.
It is a piece of flanged pvc pipe about 6-7 inches long, and then a rubber gasket that goes between the flange and the bottom of the strainer, then a nut to screw it all together.
It leaked like crazy after the initial repair, and it looked like the rubber gasket had seen better days, so I bought a new one, slapped it together. Tested it out real quick and no leaks....but as time went on and I used the sink more and more it has started leaking very slowly...but leaking nonetheless.
It has had me scratching my head and the only thing ive noticed that could cause a problem is that the flange on the pvc pipe is ever so slightly warped in one place.
I even went so far after some frustration as to apply RTV to both sides of the gasket...my shadetree mechanic skills have branched into plumbing I guess.
But even with RTV...it still dribbles out ever so often if there is a steady flow of water coming through.
Any other ideas? Im afraid I may have to get a new strainer, new piece of PVC and start all over, but Im certainly dreading that notion.
littlehoov87 is offline   Reply With Quote
Old 09-12-2012, 07:00 PM   #2
Rewards Points: 3,370
And i'll bet you used the original strainer,break down and buy all new parts,then put it together and i'd almost bet the problem is solved.
Canarywood1 is offline   Reply With Quote
Old 09-12-2012, 07:49 PM   #3
Rewards Points: 12,876
That cheap plastic strain should have been thrown in the trash.
Old 09-12-2012, 09:23 PM   #4
If that was my sink, I would bite the bullet and replace it with a metal drain. Then use plumber's putty as the gasket of choice between the sink and drain.
allthumbsdiy is offline   Reply With Quote
Old 09-12-2012, 09:37 PM   #5
Rewards Points: 582
yep do just that ..what everyone said...problem solved,...
How to fix, leak under sink, disposal bergerdude Plumbing 3 02-05-2012 11:06 PM
Loose Sink Strainer stavner Plumbing 4 09-08-2011 04:35 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
Slow leak under kitchen sink cdruet Site Help and Suggestions 6 09-06-2010 08:28 PM
Kitchen sink basket strainer hkm2 Plumbing 1 08-06-2009 07:44 AM
