Limit On Turns In Vent Stack? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2010, 01:50 PM   #1
Limit on turns in Vent stack?
I have a basement bathroom that was stubbed with drains and a vent stack when the house was built.
I'm currently working on connecting the sink drain to the vent stack. But I've got a maze of pipes from the upstairs bathroom, heating ducts, and soffit construction for building up the wall.
The net result is that I've got to navigate a maze of plumbing and wood work to get from the sink drain to the vent stack. I'm finding that it might require as many as five (5) 90 degree elbows to make a path from the drain to the vent.
I'm looking to see if there are any code problems that I might run into with this.
HooKooDooKu is offline   Reply With Quote
Old 03-19-2010, 01:24 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Not in oregon you wouldn't. The only thing they care about is the distance the vent travels either horizontally or vertically. These lengths are based on the minimum size of required vent.
Journeyman Plumber
Old 03-19-2010, 09:26 AM   #3
I called the building department late yesterday and talked to the plumbing inspector. It pretty much sounded like as long as we're talking about the "dry vent" space, you can have as many turns you need. No distances were mentioned... just the fact that I'm trying to tie into a 1-1/2" vent preinstalled by the builder (other than he reminded me of the warning that that vent stub is going to be full of water, so be ready when you cut into it).
In the end, I did indeed need 5 elbows to connect to the vent.
Old 03-19-2010, 10:05 AM   #4
Doing it myself
Alan's Avatar
There are also fixture unit specs as far as tying two vents together. Depending on what that vent was originally serving and what you were tying into it, you may need to upsize.
Journeyman Plumber
Old 03-19-2010, 11:03 AM   #5
What I'm limited to is the stub the builder supplied me with. It's 1-1/2".
When I drilled the cap, I would say that about 1 gallon of water came out. Given that this pipe has been in place for 10 years, I would guess that this vent one way or another ties into the dry vent serving the upstairs bathroom. But that's just a guess based on the water. The pipe was labelled at "vent to roof for future bath".
In my case, this is the dry vent for a single sink and tub. When I talked to the building inspector, I told him I was stubbing for a bathroom with a sink, tub, and toilet, and that I was using 1-1/2" pipe for the sink drain and sink/tub dry vent. He didn't say I needed anything larger than the 1-1/2".
can stack vent turn 90 degrees? hohadcr Plumbing 6 03-16-2010 07:45 AM
Vent stack is on other side of basement... Feretich Plumbing 5 02-12-2010 02:13 AM
Can you remove hotwater vent stack? rhino1616 HVAC 1 03-11-2008 09:43 PM
leaking vent stack joint xrayman Plumbing 10 03-04-2008 04:23 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
