Lime Build-up In Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2010, 10:16 AM   #1
Lime build-up in shower drain
Build-up in drain is causing slow drain back-up problems. What can I use to desolve deposits that will be user friendly to a septic tank system?
Joe Morgan is offline   Reply With Quote
Old 07-08-2010, 11:08 AM   #2
Knows everything but that
Rewards Points: 150
Im not sure about its septic tank safeness but Ive read that white vinegar will do the trick. I have the same problem on my glass waterfall sink. It seems I can never get the glass clean from the lime and build up. It beautiful when its clean but it was only clean when it was brand new.
JakAHearts is offline   Reply With Quote
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Clogged Shower Drain... possible lime built up? plenmao Plumbing 9 04-16-2010 08:08 AM
Fleible drain hose for shower? devouru Plumbing 1 06-25-2008 11:06 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
